Posted August 30, 2015 I know I can look this up and pretty much find the answer anywhere about how to ground yourself before you touch a component in order not to fry it but I just want to be extra sure about this before I get my parts. I just want to know your opinion or preference (unless it's fact) of the following question: A: Is an anti-static mat/wrist band worth it? If not is it at least worth the convenience? B: Before I pick up a part should I hold onto my case while I pick up the part OR touch the case, remove my hand from the case and then touch. Or is there a better alternative? C: Would having something like this... https://gyazo.com/6a7837c833098b19dbe5f6a959cf688f plugged into the wall (just the ground, obviously,) and then secured to your case with the ground wire and then using the method in question B be a good idea or not? D: Am I overthinking things and its just as simple as the method(s) in question B all there is too it... Any other tips and advice you could give would be greatly appreciated, thanks! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 30, 2015 D "In the middle of every difficulty lies opportunity." - Albert Einstein Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 30, 2015 Honestly, an anti-static wristband is not necessary, like, at all. You'll be fine just touching a metal part of your case every now and then.. CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 30, 2015 Just get an antistatic wristband i7 6700k - 32GB DDR4-2133 - GTX 980 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 30, 2015 A: Is an anti-static mat/wrist band worth it? If not is it at least worth the convenience? Not worth it. Just don't be stupid and it will be fine B: Before I pick up a part should I hold onto my case while I pick up the part OR touch the case, remove my hand from the case and then touch. Or is there a better alternative? Doesn't matter. Just make sure you are touching the case before you pick it up. Also the case might not discharge if it's not grounded, so maybe used a plugged in PSU (Make sure it's off!) C: Would having something like this... https://gyazo.com/6a...be5f6a959cf688f plugged into the wall (just the ground, obviously,) and then secured to your case with the ground wire and then using the method in question B be a good idea or not? Don't. Too much effort and could be dangerous if done incorrectly D: Am I overthinking things and its just as simple as the method(s) in question B all there is too it... You are overthinking Any other tips and advice you could give would be greatly appreciated, thanks! You're welcome Intel Core i7 9700k - EVGA FTW GTX 970 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 30, 2015 I know I can look this up and pretty much find the answer anywhere about how to ground yourself before you touch a component in order not to fry it but I just want to be extra sure about this before I get my parts. I just want to know your opinion or preference (unless it's fact) of the following question: A: Is an anti-static mat/wrist band worth it? If not is it at least worth the convenience? B: Before I pick up a part should I hold onto my case while I pick up the part OR touch the case, remove my hand from the case and then touch. Or is there a better alternative? C: Would having something like this... https://gyazo.com/6a7837c833098b19dbe5f6a959cf688f plugged into the wall (just the ground, obviously,) and then secured to your case with the ground wire and then using the method in question B be a good idea or not? D: Am I overthinking things and its just as simple as the method(s) in question B all there is too it... Any other tips and advice you could give would be greatly appreciated, thanks! Step 1, find anything and everything fluffy in your house. Pets, pillows. blankets. ALL OF IT. grab it. put it into a pile Step 2. Roll around in this pile. like for atleast 8 hours. Step 3. get ballons. blow up balloons. attach them to yourself via your newly found static powers. Step 4, rub any and all pets one final time for good measure Step 5, avoid touching anything metal this includes your case Step 6, touch ALL of your pc parts. rubbing your pet in between each touch of a part. Congrats, you now own a paperweight. Pls do not do this. CPU: i7 6700k @4.5GHZ | Mobo: MSI Z170 Gaming M5 | RAM: G Skill Rip Jaws V- 16GB | GPU: Sapphire RX 5700 XT | Storage: Seagate Barracuda 2TB 7200RPM, Seagate Barracuda 500GB 7200RPM, Kingston SSD-now 100V+ 128GB, WD Black 600GB, WD Blue 500GB, Intel 600p 256GB nvme SSD |PSU:Corsair CX750M| Cooling: Corsair H60| Displays: 27" LG IPS277L, Samsung Curved 72hz Freesync 27 inch, Epson EX7220 Projector with 100 inch 16:10 Screen | Kb: Corsair Vengeance K70 | Mouse: R.A.T. 4 | Case: NZXT Phantom 410 (Red) | OS: Win 10 Home 64 Bit Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 30, 2015 Just touch your freaking case.. I don't know why people get so over worked about this. . Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 30, 2015 Touching a metal part of the case is fine but a wrist band gives extra assurance at least to me. CPU: I7 4790k CPU Cooler: NH-D15 GPU: MSI 970 4gb Motherboard: z97 Gaming 5 PSU: Corsair hx850 Ram: Corsair Vengeance 8 gb SSD: Samsung 850 Evo Case: Air 540 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 30, 2015 I have never used an Anti-Static band when building any computer. I just place a metal sheet on the floor and stand over it. It worked well. Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 30, 2015 Author Just touch your freaking case.. I don't know why people get so over worked about this. Because there's a possibility of throwing hundreds of dollars out in the window in 2 seconds if something gets shocked.. lol Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 30, 2015 Because there's a possibility of throwing hundreds of dollars out in the window in 2 seconds if something gets shocked.. lol Surprisingly electrical components are pretty resilient. Just don't have wild kinky sex on a shag carpet and you're fine. . Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 30, 2015 Basically as long as you don't work on carpet you'll be fine. And touch your case once in a while. Case Phanteks Enthoo Evolv ITX | Motherboard Asus ROG Strix Z270i | CPU Intel i7-7700K | RAM Team Vulcan 16GB DDR4 | GPU Geforce GTX 1080 Ti | Storage Crucial MX300 1TB M.2 | PSU Corsair RM750x Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 30, 2015 Most modern parts should have some resistance to static but its best not to try to ruin the damn thing by not thinking! Lake-V-X6-10600 (Gaming PC) R23 score MC: 9190pts | R23 score SC: 1302pts R20 score MC: 3529cb | R20 score SC: 506cb Spoiler Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600, 6-cores, 12-threads, 4.4/4.8GHz, 13,5MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1, A2, B1 & B2: DDR4-2666MHz CL13-15-15-15-35-1T "Samsung 8Gbit C-Die" (4x8GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros) Zen-II-X6-3600+ (Gaming PC) R23 score MC: 9893pts | R23 score SC: 1248pts @4.2GHz R23 score MC: 10151pts | R23 score SC: 1287pts @4.3GHz R20 score MC: 3688cb | R20 score SC: 489cb Spoiler Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35MB cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2607MHz (T.S.M.C. 7nm FinFET) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A2 & B2: DDR4-3600MHz CL16-18-8-19-37-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel) Vishera-X8-9370 | R20 score MC: 1476cb Spoiler Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter Godavari-X4-880K | R20 score MC: 810cb Spoiler Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter Acer Aspire 7738G custom (changed CPU, GPU & Storage) Spoiler CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD Complete portable device SoC history: Spoiler Apple A4 - Apple iPod touch (4th generation) Apple A5 - Apple iPod touch (5th generation) Apple A9 - Apple iPhone 6s Plus HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM) Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange) Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow) Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6 Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue) Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold) Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1 Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
