Hey guys. I am experiencing crazy RAM usage from the NT Kernel & System process. I don't know how I can get it down. My PC is only a week old. I can't figure out why it's sky high like this. Here is a screenshot.
post-238330-0-69638300-1436478765_thumb.
AMD Ryzen 5 3600, ASUS B350-F Gaming, Trident Z RGB 3200MHz 16GB, PowerColor Red Devil 5600 XT, NZXT H500, 1x512GB Seagate Barracuda NVMe, 2x2TB Firecuda 7200RPM, 1x250GB Intel SSD (Cache), 1x4TB Seagate 7200RPM Ironwolf (Backup), 650w EVGA Bronze
https://linustechtips.com/topic/403896-need-help-crazy-memory-usage/
do you only have 1gb of ram???
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
I originally had 8 but one of the sticks went bad so I have to grab another kit. I have 4GB of RAM right now.
ok
prob virus scan
It's probably running an update
or some background optimization stuff, chill out...
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
500MB is normal...
thats barely any ram
my system processes usually use 2-3GB
no programs running
perfectly normal
500MB is normal...
no programs running
perfectly normal
My coworker said the same thing. That's crazy. So is it just sitting things to retrieve for later? I'm still going to run the virus scan too though.
its an operating system...
all operating systems use ram...
you cannot have an OS running without it using ram
windows usually uses a few GB, not sure why yours is only 600MB
if you are really at 88% of your 4GB then theres probably something else using more ram
because 600/4000 is not 88%
That looks like windows 10. Windows 10 is not released yet, so, it could literally be anything at this point. 500 is not terribly much, though, and a system will scale its idle usage based on how much ram you have. So a 2GB system will use a couple hundred MB, 4GB more, 6, 12, etc.
My 16GB system uses about 1-2GB idle. But my 2GB system uses less than 500mb
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
Yeah, it is windows 10. This could be the culprit.
Probably not a virus or Windows 10 related.
It seems like a driver problem from first inspection or a hard pagefault. You could find out by checking the number of interrupts using something like LatencyMon or Xperf.
▶ Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning. - Einstein◀
Please remember to mark a thread as solved if your issue has been fixed, it helps other who may stumble across the thread at a later point in time.
Omw home about to check it out
#1: IF you did NOT use your system for lets say a month or 2 this is normal since its gonna want to update windows (i know from experience , i didnt use my laptop for a year and when i did use it it was unusable for 6h due to 187 updates it was trying to download , run , bla bla bla)
#2: Virus , Malware etc. Make sure you run a full system sweep with an anti virus
#3: Get more ram
#4: if you literally have a system with a max ram of 2gb...time to upgrade my friend :)
#3: Get more ram
No I don't have 2 gigs. I have 4. Had 8 but one chip went bad lol.
you've got 10 google chrome tasks running i see. Try ending all the chrome tasks. Web browsers chew up ram. If thats not the problem then idk but something is deffanatly happening behind the scenes.
Case: Corsair 760T White PSU: Corsair AX1200i Motherboard: Asus Maximus VII Formula CPU: I7-4790k Cooler: Stock Cooler Ram: Corsair Vengeance 16GB 2400mhz GPU: Asus Strix GTX 970
Maybe don't use chrome that thing eats up ram like no tomorow.
I tried. I a boot with no start up programs after 10 minutes NT Kernel and System still mercing the RAM stick.
well my windos uses about 2-3 GB of ram.
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
It's windows ten, re install.
/Thread
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
