To All G1 GTX 970 Owners, How Are My Temps
Shaan5
Here are my Overclock Settings
Power Limit: 112%
Memory: +300 (3806MHz)
Core: +130 (1510MHz)
No adjustments have been made to the Voltage
At idle I get Temps in the Low-High 30's When I'm Overclocked or at stock
Under Heavy Gaming Load
Stock: Temps Max At 60-65 Degrees Celsius
Overclocked: Temps Maxed At 64-68 Degrees Celsius (Sometimes Hitting 70C)
I noticed A Difference in Temperatures but the Difference In FPS Was much more easy to Spot bumping the FPS by around 10% in most games with no Stability issues(As Far as I can tell)
Thanks
 Case: Define R5 I GPU: G1 GTX 970 I CPU: i5 4690k I RAM: G.Skill Ripjaws X I PSU:  EVGA 750B2 I Cooler: Noctua NH D15
MB: ASUS Z97-A I SSD: Crucial MX100 256GB I HDD: WD Black 1TB
Should I buy the 970 or the 290?
24 fps for that "cinematic" feel
After a couple weeks of behavioral sciences at my school I can easily conclude my parents need to grow up.
Temperatures look good.
Perfect and where they should be.
970 beats it.
970 beats it.
I know that but the 290 is so cheap. How much does it beat it by.
My card idles at 63C. (Fan doesn't turn on.) and under load, it goes up to 75C. I don't sweat it, so I'd say you're perfectly fine!
10-15% at most.
Also  @Shaan5 those temps look fine.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
This is just one benchmark provided by Anandtech.
Those are pretty much the same temps that I'm getting.
GPU: Gigabyte GTX 970 G1 Gaming CPU: i5-4570 RAM: 2x4gb Crucial Ballistix Sport 1600Mhz Motherboard: ASRock Z87 Extreme3 PSU: EVGA GS 650 CPU cooler: Be quiet! Shadow Rock 2 Case: Define R5 Storage: Crucial MX100 512GB
I can save around $60 if I get the 290..... ahhh I'm in a dilema!
Then get a 290. You'll be happy with it.
Yup, getting the 290 + 8350 combo
Save 60 bucks.
Build: CPU: i7-4790k @4.4 GHz 1.2v | GPU: Sapphire R9 380 Nitro | Memory: 16GB Evga SSC | Storage: 250GB 850 Evo, 1 TB Toshiba HDD | Mobo: Gigabyte GA-Z97X-Gaming 7  | Cooling: Aigo T120 RGB | Case: NZXT S340 | PSU: Antec HCG 520w | OS: Windows 10 | Keyboard: Corsair K70, Cherry MX Reds | Mouse: Logitech G600 | Monitor: LG 27UD58-B | Headset: Audio-Technica M40x w/ Modmic and Bravo Audio V2 Tube Amplifier
Do you already have an FX motherboard or something? Or are you buying for an entirely new build?
I bought an old barebones build form my friend and I'm just upgrading the Mobo, GPU, CPU. I'm considering getting the http://www.newegg.com/Product/Product.aspx?Item=N82E16813157582
My Strix 970 used to idle at 60C... Load of 74C. You are perfectly fine... Too bad my Strix fucking died today...
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
I bought an old barebones build form my friend and I'm just upgrading the Mobo, GPU, CPU. I'm considering getting the 990FX board or this: http://www.amazon.com/gp/product/B008V9959O/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&camp=1789&creative=9325&creativeASIN=B008V9959O&linkCode=as2&tag=item0b5-20&linkId=O7UQ7YWOS4HE665G
Get an i3, im not an intel fanboy by any means, but you will have more upgrade-ability. The 8350 will beat the i3 over all, but the i3 has stronger single core performance.
Doesn't the 8350 destroy all of the i3s...
The 8350 does ultimately beat the i3 but the i3 has stronger single core performance, and you will have the option to upgrade to a i5 or i7 later down the road.
An 8350 is still a great cpu though, actually just get that. :)
By the time I want to upgrade the Haswell series will be very old, I'll want the i5-7XXX by then.
By the time I want to upgrade the Haswell series will be very old. By the time I upgrade I'll want the i5-7XXX.
Lol, good point :)
So, go with the 8350 :)
