Minecraft running at 45 FPS on a GTX 970
Solved by D3MON,
did that, no change
if its online then it could be a case of ripple/lag as there is a bit of a disturbance between your movement and the sever getting the information and updating your position etc, while a laggy connection waits to update your pc has nothing to do so your gpu usage drops and spikes very quickly (as seen) and your fps is low, if you use afterburner to monitor frametimes you'll probably see huge spikes.
see if it happens in single player on a similar sort of area.
why is it most minecraft shops suck and lag to hell (actually i can guess its all the players)
