No.  It maxes available VRAM as a buffer.  So whatever you have it will use.  This is an estimated guess.  I have not looked into it.
So me having .5gb more vram mean i can perform better than 780ti like in texture rendering..etc even though 780 ti can also run it?
So how much vram does advanced warfare use? when i had afterburner on it shows 3.5gb usage but you said its a buffer of maximum available vram.
https://linustechtips.com/topic/299496-my-build-help/page/21/#findComment-4590591
Possibly.
IDK.
It could be a buffer.  :)
https://linustechtips.com/topic/299496-my-build-help/page/21/#findComment-4591162
Possibly.
IDK.
Funny story
I used to game on my sony laptop, it was not a gaming laptop or anything but i was able to run cod4 modern warfare at 800x600 lol on low setting. Despite the lack of detail and blurry gameplay, i was a beast in multiplayer lol But i had problem with low res, i couldnt see enemy across the map, the only time i would barely see it is when i see a dot movement lol
Good times, hard trouble finding the game again but found one last night and installing now. FInger Crossed
https://linustechtips.com/topic/299496-my-build-help/page/21/#findComment-4597871
I can see myself starting a new game (online fps)... but my better sense won't let me do it.  I know what I am like and I don't want to lose months playing COD4. =D
@winkawak
Well practices self control lol, everything requires self control and moderation.
Cod is the same lol
come, join me lol
https://linustechtips.com/topic/299496-my-build-help/page/21/#findComment-4610057
Cod is the same lol
come, join me lol
nope!  I won't do it.  :lol:  I have not played any COD online.  If it is worth playing, it will suck up too much time.  I am not willing to do that.
https://linustechtips.com/topic/299496-my-build-help/page/21/#findComment-4610137
I dont get it, its just another game you can play on your freetime.
Unlike heroin or crack which you have to be on constantly lol
https://linustechtips.com/topic/299496-my-build-help/page/21/#findComment-4612434
i noticed when i play cod4 online everything is maxed out and constant 95fps, the temp will be 60-65c. This is the borderline temp when the fan kicks in, so i have been observing and fan does kick on and off very frequently. WIll this wear my fan out?
https://linustechtips.com/topic/299496-my-build-help/page/21/#findComment-4633433
Nah, it can just be annoying... I believe you can control the "dead zone" for you fans so they do not go on and off so frequently.
https://linustechtips.com/topic/299496-my-build-help/page/21/#findComment-4633532
what do you mean by dead zone? can i use msi afterburner to set temp when fan kicks in?
Yeah, kinda.  Linus just did a video on someone's guide to make ANY GTX 970 like the Strix.  You can manipulate all the settings.
http://linustechtips.com/main/topic/339874-how-to-enable-fanless-mode-in-gtx-900-series-video-cards/#entry4633694
You could also just try to manually set them for that one game... so they keep spinning, but at a low rpm.
https://linustechtips.com/topic/299496-my-build-help/page/21/#findComment-4635471
video tutorial is so much hassle with all the tools you have to download and adjust, how do i just manually set for one game?
https://linustechtips.com/topic/299496-my-build-help/page/21/#findComment-4636031
I do it in Catalyst Control Center.  I am not sure about Nvidia.
Try using Asus GPU Tweak to customize the fan curve.  Afterburner might mess with your silent mode.
https://linustechtips.com/topic/299496-my-build-help/page/21/#findComment-4638521
