I would try to fit an SSD in there somewhere
You are going X99 and CLC with no SSD...... come on man!
CPU i5 3570k MOBO Asus Maximus Gene V GPU Asus DCUII 670 CASE Corsair 350D (windowless) SSD Crucial M550 256GB msata CPU COOLER Noctua NH-D14 RAM Corsair XMS3 8GB 1600mhz PSU Corsair AX750 Display Asus PB287Q 4K (my review on it http://linustechtips.com/main/topic/380533-journey-into-4k-goodness-asus-pb287q-review/) & Asus VH236H 1080P
Keyboard Logitech G710+ MX Brown Mouse Logitech G502 (my review on it http://linustechtips.com/main/topic/299464-logitech-g502/ )
Proud owner of a BlackBerry Q10.
https://linustechtips.com/topic/299496-my-build-help/#findComment-4067355
^^ Yes, get an SSD if you can, makes the whole system much quicker. Also, I would personally get a MSI or ASUS GTX 970, the EVGA one (I have this one) actually has heatpipe issues.
http://www.guru3d.com/news-story/evga-geforce-gtx-970-acx-has-misaligned-gpu-vs-heatpipes.html
Not sure if they have addressed it or if it's only with the ACX 1.0 coolers.
Personal thoughts on my EVGA GTX 970:
No coil while unless running VERY HIGH FPS.
Looks meh, MSI and ASUS look better IMO.
Again, the cooler problem
The blue accents appear to be stickers (though it doesn't looks like it'll come off anytime soon).
i7-4790K @4.0 GHz [] Asus Z97 Sabertooth Mark II [] 16GB (2x8GB) Corsair Vengeance Pro 1866MHz [] EVGA GTX 970 SC [] Corsair Carbide Series Air 540 [] Samsung 840 Series SSD [] Corsair HX750 [] Samsung S27D390HS 27" [] Razer Blackwidow Ultimate 2014 [] Corsair M65 RGB [] Razer Kraken Pro [] Windows 8.1 [] http://pcpartpicker.com/user/jix/saved/kYWPxr
https://linustechtips.com/topic/299496-my-build-help/#findComment-4067396
Im new to building desktop whats CLC? Can SSD is expensive lol. What does SSD do beside faster loading? Should i use it for as additional storage or installed os or program with it?
Wow thanks for the heads up. So no problems with Asus or msi?
https://linustechtips.com/topic/299496-my-build-help/#findComment-4067397
you should install programs and the OS on the SSD. it just makes things ALOT snappier
https://linustechtips.com/topic/299496-my-build-help/#findComment-4067425
CLC is a closed loop cooler, or liquid cooler, or all-in-one. Basically referring to the  Corsair H50
A 256GB SSD is a perfect size to price right now. One can be had for around 100-130
Edited by deVIZtation
https://linustechtips.com/topic/299496-my-build-help/#findComment-4067457
I posting this for you to see prices.  You have way to much power for your build.  The GTX 970- uses 3.5 GB of it's VRAM at a high level of performance.  The 970 is safe to use at 1080p or even 1440p, but if you are planning a 4K resolution experience, you want a R9 290X or GTX 980 for more VRAM.
The i7 5820K (X99) is over kill for gaming, but is great for a gaming/workstation.
The AsRock Motherboard will perform around the same as your much more expensive mobo.
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($389.99 @ Newegg)
CPU Cooler: Corsair H50 57.0 CFM Liquid CPU Cooler  ($49.99 @ Newegg)
Motherboard: ASRock X99 Extreme3 ATX LGA2011-3 Motherboard  ($160.78 @ Newegg)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR4-2400 Memory  ($109.99 @ Newegg)
Storage: OCZ ARC 100 240GB 2.5" Solid State Drive  ($79.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Newegg)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card  ($334.99 @ Newegg)
Power Supply: SeaSonic 620W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($54.99 @ Amazon)
Total: $1235.71
Generated by PCPartPicker 2015-01-27 19:14 EST-0500
There are really only two questions you need to answer:
Are you using this PC for gaming only?
Are you going to be using a 4K display?
Case:  There is a good deal on the NZXT S340.  It is made 90% of steel, very sturdy.  It looks good.  It is on sale.  ...but it has no optical bay slots:
http://pcpartpicker.com/part/nzxt-case-cas340wb1
http://pcpartpicker.com/part/nzxt-case-cas340ww1
Other cases:
NZXT H440 - lots of colours
Phanteks Enthoo (white or black) - http://pcpartpicker.com/part/phanteks-case-phes614pbk
...and many more
https://linustechtips.com/topic/299496-my-build-help/#findComment-4067459
256gb should be enough, if in doubt, up it to 512.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/299496-my-build-help/#findComment-4067460
I posting this for you to see prices.  You have way to much power for your build.  The GTX 97- uses 3.5 GB of it's VRAM at a high level of performance.  The 970 is safe to use at 1080p or even 1440p, but if you are planning a 4K resolution experience, you want a R9 290X or GTX 980 for more VRAM.
Total: $1235.71
The build i made is not just for gaming, ill need it to do 3d animation and rendering. I saw some game testing and gtx970 was able to play most games in 4k around 50fps. I will also be adding a gtx970 sli in the future, thats were my 850w comes in.
Should i get the h55 or h60 liquid cooler?
https://linustechtips.com/topic/299496-my-build-help/#findComment-4067494
GTX 970 will get rekt in 4K I think.
That's all I'll say about if since Nvidia lied to their consumers about the card having 4GB of VRAM.
I would throw an SSD on there as well. I have a 128GB and it works fine for installing Windows and a few programs I frequently use.
PCPartPicker link: http://pcpartpicker.com/p/R6GTGX
Привет товарищ ))))
https://linustechtips.com/topic/299496-my-build-help/#findComment-4067539
You don't need that much power for the 970 in SLI, 750w would do.  Now, two 290X's means you would need more around the 850W range, 1000W is more than safe.
https://linustechtips.com/topic/299496-my-build-help/#findComment-4067561
I haven't used the H55, but I have installed a h60 in a client's rig. Seems to be fine.
https://linustechtips.com/topic/299496-my-build-help/#findComment-4067568
F*uck it.  8GB of VRAM!
Video Card: XFX Radeon R9 295X2 8GB Core Edition Video Card  ($659.99 @ Newegg)
Case: Corsair 450D ATX Mid Tower Case  ($114.99 @ NCIX US)
Power Supply: EVGA SuperNOVA 1000G2 1000W 80+ Gold Certified Fully-Modular ATX Power Supply  ($109.99 @ Newegg)
Total: $1730.70
Generated by PCPartPicker 2015-01-27 19:33 EST-0500
https://linustechtips.com/topic/299496-my-build-help/#findComment-4067594
On sites like ibuypower/cyberpower says i need 850w to run gtx970 sli, idk. Im just using their site as reference.
That's all I'll say about if since Nvidia lied to their consumers about the card having 4GB or VRAM.
So i need a sata3 ssd? i dont see any cheap/good 256gb ssd.
As long as H50 keep my 5820k cool, im fine.
https://linustechtips.com/topic/299496-my-build-help/#findComment-4067614
It is not true, not even close.
Cheap and good:  http://pcpartpicker.com/part/ocz-internal-hard-drive-arc10025sat3240g
http://pcpartpicker.com/part/sandisk-internal-hard-drive-sd6sb1m256g1022i
http://pcpartpicker.com/part/mushkin-internal-hard-drive-mknssdcr240gbg2
http://pcpartpicker.com/part/samsung-internal-hard-drive-mz75e250bam
https://linustechtips.com/topic/299496-my-build-help/#findComment-4067633
I just read the article, this f uckers lol.
I helped a friend who wanted to go, in his words, "full retard".  A few months back his X99 + R9 295X build cost him $3500 or so... monitor included.
Too much, he must be rolling in gold. My budget is 2k.
All these vram talk, im thinking about going gtx980 instead, since gtx970 only has 3.5gb of vram. Btw how much better is gtx980 over gtx970?
https://linustechtips.com/topic/299496-my-build-help/#findComment-4067649
I have a Crucial MX100 128GB. I thought it was reasonably priced when I purchased it when taking into consideration what I'd actually be putting on the drive. It has worked well for me thus far.
Привет товарищ ))))
https://linustechtips.com/topic/299496-my-build-help/#findComment-4067650
Are you so against the R9 295X?  The card kicks ass.  At under $700 it beats a single 980 by a hell of a lot... going to double check...
Two 980's beat it all around by 10%, but two 980's cost over $1000.
https://linustechtips.com/topic/299496-my-build-help/#findComment-4067676
What resolutions will you be doing stuff at?
The 970 will be fine if doing stuff at 1080p, and the 980 might be overkill for it, although I personally still wouldn't recommend the 970 since Nvidia lied. Their ethical practices are more important to me than the actual performance of the card, but if you don't care about that and will only be doing 1080p then go for it.
Привет товарищ ))))
https://linustechtips.com/topic/299496-my-build-help/#findComment-4067687
same page has a 256gb, reasonably priced too.
Im not lol, im just not familiar with amd and rumor about their lack of update on their gpu. I dont really care actually, i want the product that will give me most bang out of bucks. It can be AMD or Nvidia.
I feel you lol i see that bold red 3.5gb lol Overall its not a bad card but the lies tho
https://linustechtips.com/topic/299496-my-build-help/#findComment-4067694
