Hey guys i need help to choose if this build worth the green more than the asus rog gr8 http://www.asus.com/...te/rog/GR8_G20/remember it has a free asus rog gladius mouse and a mechanical keyboard so both of it maybe worth 150$ to say the least
intel core i5 4690k
cooler master hyper 212 evo
msi z97 sli krait
kingston fury white 1866 8gb
wd green 1tb
gigabyte gtx 960 g1
nzxt s340
evga supernovanex 650w 80+gold
this build is worth 1170.77 dollars plus shipping im from uae ,dubai so shipping is expensive the asus rog gr8 costs 975.65 is the performance worth it? help please
https://linustechtips.com/topic/299496-my-build-help/page/22/#findComment-4638767
intel core i5 4690k
msi z97 sli krait
wd green 1tb
gigabyte gtx 960 g1
nzxt s340
You should make your own thread to get more members to see it...
The build is fine, but I don't know about pricing in your country.  The GTX 960 is okay but if you can find a much cheaper R9 280 can go with that... or if you can find a R9 280X or R9 290 for the same price as the GTX 960, definitely go with that.
Do you have a store where you are selecting parts from?
Also, the ROG motherboard is not worth the money... it does not improve performance at all.
https://linustechtips.com/topic/299496-my-build-help/page/22/#findComment-4638798
With all the horror games that came out recent years, evil within is one of the top ones that actually have a resident evil 4 feel to it. But its badly optimized, if i remove the 30fps cap to 60 it will be unstable and stutter and not to mention the big ass black bars .I also got alan wake, outlast and dying light waiting to be played next. I noticed alt of bad optimized pc games in these recent years.
What games are you playing stconquest?
https://linustechtips.com/topic/299496-my-build-help/page/22/#findComment-4641345
Cities Skylines, LoL, and that is pretty much it.  I have some time in Dying Light, but I have not touched it in about a week... same with Tomb Raider and Minecraft.
lol what kind of gamer are you? you abandon aaa games like tomb raider to play skylines lol?
I wanted to get into sims but i find it slow and booring lol
https://linustechtips.com/topic/299496-my-build-help/page/22/#findComment-4642129
Sims, Cities, Minecraft... these are great games to multitask with...
Watch videos/tv/movies and play :lol:
https://linustechtips.com/topic/299496-my-build-help/page/22/#findComment-4642136
My case developed this light rattle on top of the case where the filters are. Once awhile i have i push on it or nudge it to make it stop.
I actually got that on my current rig.  You can take the fans off and redo them.
For mine, I was lazy.  I just loosened the screws a bit.  ;)
https://linustechtips.com/topic/299496-my-build-help/page/22/#findComment-4673840
Its the fan? doesnt sound like rattle from fan rather the plastic near it like the filters on top or something. The top fan is actually my case cpu fan that i moved to the top since my h60 came with back fan. Im thinking about removing top fan to reduce fan noise and rattle. But im not sure if its needed for better cooling or ill be okay without it during gaming. Now come to think of it I might needed since everytime when i game i can feel quite bit of heat coming out from the top fan.
https://linustechtips.com/topic/299496-my-build-help/page/22/#findComment-4675669
  • 2 weeks later...
If i backed up my current hard drive with programs like games and software on it to another hard drive, does it mean when my current hard drive fails i can just plug in my back up hard drive and no program re installation required?
If you clone the drive, yes.  You would have two identical drives.
https://linustechtips.com/topic/299496-my-build-help/page/22/#findComment-4783885
Windows has an imaging program, or you can use a 3rd party program like Clonezilla.  You don't have to "backup" the drive as much as you just make an image of the drive and store it somewhere.  It should take up a lot less space.
ok, im just making sure the clone hard drive will work and have all the files like the old hard drive just by plugging it in in case old one fails.
i was reading this article and it states most mechanical hard drive fail rate starts to increase after 1 year and most life span is 3-5years. makes me wonder and worry, ill get another wd blue to back up my current one.
https://linustechtips.com/topic/299496-my-build-help/page/22/#findComment-4784072
The article you read either was not talking about desktop drive usage or was very pessimistic. In my experience hdd in most desktop systems tend to last well past 5 years. In fact many last 8 - 10 years.
Cloning a drive would allow for swapping in the replacement drive as needed. However, the system would revert to when the clone image was made. Unless you frequently refreshed the clone image, say at least weekly, there would still be a need to bring the image up to date.
It would be better, in my opinion, to install good backup software and have it automatically backup the drive on a daily basis. Take a look at products like Acronis True Image. It can create an maintain a full image backup with relatively painless restoration.
https://linustechtips.com/topic/299496-my-build-help/page/22/#findComment-4784409
Coning a drive would allow for swapping in the replacement drive as needed. However, the system would revert the system to when the clone image was made. Unless you frequently refreshed the clone image, say at least weekly, there would still be a need to bring the image up to date.
thanks amigo
https://linustechtips.com/topic/299496-my-build-help/page/22/#findComment-4785252
Fair warning:  Acronis True Image is not free, you do have to pay for it.  Clonezilla clones a drive in roughly 10 minutes.  So spending 10 minutes a week backing up your drive is not a big deal.
ill use clonezilla lol
its reliable and easy right?
https://linustechtips.com/topic/299496-my-build-help/page/22/#findComment-4785376
Reliable yes.
Easy for me, can be for you too...lol...
It is hard to use until it is not hard to use... just a tiny learning curve.  When you do it once or twice successfully, you realize how simple it is.
Let me find you the video I watched first.
You can boot Clonezilla from a disc or from a USB drive.  I use a disk because I have so many blanks.
https://linustechtips.com/topic/299496-my-build-help/page/22/#findComment-4785604
