Yup.
You did hear DirectX 12 will use a single pool of VRAM from multiple GPUs, right?  So two of your 970s will add their RAM together.
wait wat, i thought you cant stack vram? So with dx12 games i vram will stack? thats great, what else does it stack lol?
https://linustechtips.com/topic/299496-my-build-help/page/20/#findComment-4512316
lol
did alittle reading about it, wow even works with 2 different brand gpu, wonder if gpu has to be equivalent or one can be like 970 or other one 980. Article also states it will be hard on developers to make this work and efficiently. I have doubts, just look at some games out there thats already having problems with just 1 gpu cough.....far cry 4......metro.....AC unity.....etc
https://linustechtips.com/topic/299496-my-build-help/page/20/#findComment-4512554
While battlefield 4 is very pretty to look at with its high level of detail but the gameplay is awful.
Heres some main cons i have
1. It has a strong aim assist feature in single story and theres no way to turn it off. The aim assist assists way too much and takes fun out of shooting games.
2. character movement is very sluggish almost feels heavy if it makes sense.
3. enemy targeting system does not always work
4. AI constantly gets in the way of you. Door and stairs is a pain, you must let them go first or youll get pushed to the side.
5. while accessing weapon stack in game you cant exit out with the controller youre playing and must use mouse to click done to exit
https://linustechtips.com/topic/299496-my-build-help/page/20/#findComment-4520907
my gpu driver was automatically installed through windows update when i first setup my desktop, im trying to update my driver to 347.88 but not sure what folder i should installed it in when it asks. I have nvidia corp folder in both my program file and program file 86.
https://linustechtips.com/topic/299496-my-build-help/page/20/#findComment-4526943
There should be a default location when you run the setup.  Pick that one.  Other than that, idk.
https://linustechtips.com/topic/299496-my-build-help/page/20/#findComment-4527153
Ok i figured it out, when i clicked on the exe icon it wanted to know where to extract the files to and not actually installing it yet.
I got it installed, can i delete that "Nvidia" folder in my c drive?
https://linustechtips.com/topic/299496-my-build-help/page/20/#findComment-4527977
I remember that thing (folder) from when I had a Nvidia card, I always left it as it was a small folder.  IDK, delete it and find out :lol:
https://linustechtips.com/topic/299496-my-build-help/page/20/#findComment-4528314
This is weird and i hope its the game.
So im playing cod advanced warfare story mode, the first mission its pretty smooth with slightly stutter(gpu usage 80-99%) from time to time but it unplayable in mission 2 (gpu usage keep dropping 10-99%). Although fps was always 110+.
Battlefield 4 was butter smooth throughout except for autosave points where slight stutter for split second but i think thats normal.
Is this faulty gpu or game?
https://linustechtips.com/topic/299496-my-build-help/page/20/#findComment-4562735
After changing nvidia control panel power management form adaptive to maximum for metro it helped alot. But it still has lag feel to it. I wonder what else it is causing it.,
As for advanced warfare it turned out the stutter was caused by cache sun shadow maps and cache spot shadow maps. Both off i no longer experienced stutter. It is weird how it didnt effect mission 1.
Another problem i have is slight laggy cutscenes for battlefield 4 and advanced warfare. Both cutscenes are capped at 30fps but gpu usage is below 5%.
https://linustechtips.com/topic/299496-my-build-help/page/20/#findComment-4574426
Videos a lot of the time are capped.
https://linustechtips.com/topic/299496-my-build-help/page/20/#findComment-4574525
