Locked out of my BIOS! Please help
Maybe press the CMOS reset button? It should reset any of the settings that you put on the motherboard that may have caused it to not allow you to go into the BIOS. It will also reset any of your settings that you have inputed/overclocks/anything like that, so just be aware that you will have to change settings. I would suggest continuing to try other things, and if nothing works go to that solution.
Featured Topics
Stin6667 ·
Posted in Graphics Cards5 -
avidgamer121 ·
Posted in Troubleshooting0 -
DZONS ·
Posted in New Builds and Planning11 -
dolphinofthesky ·
Posted in CPUs, Motherboards, and Memory10 -
IR76 ·
Posted in Networking4 -
WackySpace ·
Posted in Graphics Cards1 -
8
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
