So I finally got around to hooking up my intake fans (Forgot to when doing the build) and setting all of my case fans on the included fan controller on my case. (3 120mm intake fans, 1 120mm exhaust fan, and a 140mm exhaust fan) And my temps dropped dramatically (of course)
(All in Celsius of course)
Ambient: 22
My old idle temps:
OC'D CPU: 45
GPU: 49
My current idle temps:
OC'D CPU: 29
GPU: 27
(And surprisingly it's completely silent, I can't hear it at all even when running it with the side panel off)
So this got me curious. what does your system idle at?
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/249965-your-idle-temps/
With all my fans at 5v, 30c on cpu and around 30-45 on gpu depending on if the monitor is asleep or not
These are my idle temps, but my idle isn't really idle as I run a 24/7 ts server and usually have a mine craft server on as well
https://linustechtips.com/topic/249965-your-idle-temps/#findComment-3427287
So I finally got around to hooking up my intake fans (Forgot to when doing the build) and setting all of my case fans on the included fan controller on my case. And my temps dropped dramatically (of course)
My old idle temps:
OC'D CPU: 45
GPU: 49
OC'D CPU: 29
GPU: 27
oc'd cpu 30-40c multitasking 60-70 benchmarking 80-90
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/249965-your-idle-temps/#findComment-3427289
OC'D CPU: 32C
OC'd GPU's : 50C(top card) 45C (bottom card)
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/249965-your-idle-temps/#findComment-3427293
FX-8350 and GTX 770
AMD FX-8350|Asus M5R97 2.0|Kingston HyperX Blu 8GB|Asus GeForce GTX 770 DirectCU II|Rosewill Blackhawk Mid Tower|Seagate Barracuda 1TB 3.5" 7200RPM|Corsair CX600M|Samsung SyncMaster 205BW|Cooler Master Hyper 212 Evo|CM Storm QuickFire Rapid - Tenkeyless (Brown)|Zowie EC1 Evo Black|Razer Tiamat 2.2 Headset|Windows 8.1|
https://linustechtips.com/topic/249965-your-idle-temps/#findComment-3427308
  • CPU: 3930K @4,7GHz,  ~35°C
  • GPU: GFX 680 @1372MHz, ~32°C
But there is a lto of variables to this question. Currently my window is open, and it's getting cold in here.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/249965-your-idle-temps/#findComment-3427309
https://linustechtips.com/topic/249965-your-idle-temps/#findComment-3427331
Ambient of 22c.
33c idle at 4.6GHZ under Noctua NH-D15
980's idle around 25-28c.
i7 5930k . 16GB Corsair Vengeance LPX 2666 DDR4 . Gigabyte GA-X99-Gaming G1-WIFI . Zotac GeForce GTX 980 AMP! 4GB SLi . Crucial M550 1TB SSD . LG BD . Fractal Design Define R2 Black Pearl . SuperFlower Leadex Gold 750w . BenQ GW2765HT 2560x1440 . CM Storm QF TK MX Blue . SteelSeries Rival
i5 2500k/ EVGA Z68SLi/ FX 8320/ Phenom II B55 x4/ MSI 790FX-GD70/ G.skill Ripjaws X 1600 8GB kit/ Geil Black Dragon 1600 4GB kit/ Sapphire Ref R9 290/ XFX DD GHOST 7770
https://linustechtips.com/topic/249965-your-idle-temps/#findComment-3427349
FX-8350 and GTX 770
*Snip*
8C?! Pull your PC out of the freezer and resubmit lol.
https://linustechtips.com/topic/249965-your-idle-temps/#findComment-3427356
This has too many variables. Like ambient, geographic location, types of case/fans/heatsinks, used hardware.
I'm not sure what you're hoping of getting out of this topic.
Just curious as to what most peoples idle temps are. Not really trying to get hard data off of this. Just curious really.
https://linustechtips.com/topic/249965-your-idle-temps/#findComment-3427357
CPU: 32C GPU: 24C
 Motherboard - Asus Z97-WS ll Processor -Intel i7-4790K ll Cooling- Custom Loop ll RAM - Corsair Dominator Platinum 16GB(2x8) @2400 ll Graphics Card  - EVGA GeForce GTX 980 TI ll PSU - Corsair AX 1200 Watts ll SSD - Samsung 840 Pro 256GB ll HDD - seagate barracuda green 2TB & Seagate 4TB ll Case - Silverstone TJ11 ll Audio - Asus Xonar Essence STX  ll OS- Win 10 PRO 64-bit ll Keyboard- CM Storm QuickfireTK Green Switchesll Mouse- Logitech G502
https://linustechtips.com/topic/249965-your-idle-temps/#findComment-3427362
1:56am - Room is 26*c (Straya)
4690 (3.9Ghz Constant) does not declock even under full load (speedstep disabled+ Asus multi lock)
Sitting currently in a small enclosure under desk.
36-40*c (with 1-5% idle usage at random from my apps)
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/249965-your-idle-temps/#findComment-3427370
CPU: ~35C @ 4.8GHz
GPU: ~38C @ 1500MHz
https://linustechtips.com/topic/249965-your-idle-temps/#findComment-3427406
CPU: 4GHz 28
GPU: 1500Mhz 30
GPU: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 @1500mhz + 8000Mhz CPU: Intel Core i7 6700k Delided and Overclocked @4.8  MB: ASUS MAXIMUS VIII IMPACT  RAM: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory CPU Cooler: Corsair HG10+ H90 +H90 CASE: Corsair 380T  Storage: 120GB Samsung Evo SSD + Crucail 256GB Mx100 + 2TB Seagate/  OS: Windows 10 64bit Power supply:  Corsair RM750
https://linustechtips.com/topic/249965-your-idle-temps/#findComment-3427489
Recently, they've been a touch on the erratic side, but generally, they are at about 27 (CPU) and 32 (GPU)
They stay below 55 on load; which is pretty awesome considering that the airflow in my case is terrible (not cable management, but because it's a converted G5)
Compatible with Windows 95
https://linustechtips.com/topic/249965-your-idle-temps/#findComment-3428893
