Loud fans in my case.
eluzionn
Hi,
I have a Corsair Graphite 600T and i hate the 200mm fans , they are really loud , so could you guys suggest me some quiet 200mm fans for my case!
Thanks in advance
The bitfenix spectro pro 200mm fans are super quiet and push 148.72 cfm
here is a link to the one I have in the front of my HAF XM case http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=36_327_1133&products_id=32934 and the place I bought it from
My Sig Rig: "X79 (3970X) -Midas"http://pcpartpicker.com/p/wsjGt6"  "Midas" Build Log - https://linustechtips.com/main/topic/59768-build-log-in-progress-code-name-midas/
"The Riddler" Custom Watercooled H440 Build Log ( in collaboration with my wife @ _TechPuppet_ ) - http://linustechtips.com/main/topic/149652-green-h440-special-edition-the-riddler-almost-there/
*Riptide Customs* " We sleeve PSU cables "
Supposedly these won't fit on the top, just the front. Fortunately the top of the 600T seems to allow you to install 2x 120mm in the top instead.
