It sorta exploded. Too weak? (Corsair RM650)
SnaKz
Hey guys. So my PSU kinda exploded, PC shutdown followed by a big pop.
I'm was using a Corsair RM650,no overclocking.
The Specs:
Asus Maximus Hero VII
Intel i7 4790K
Asus GTX 780 DirectCU II OC
1 HDD & 1 SSD
8GB of HyperX RAM (2 sticks)
Corsair H100i
5 Corsair Fans
So was the RM650 not strong enough? If not then what would cause it to explode? O.o
Honestly it should be enough.. just RMA it back to Corsair.
Interested in Business and Technology
The Specs:
Intel i7 4790K
1 HDD & 1 SSD
Corsair H100i
5 Corsair Fans
650 should be enough...
Might've been something that got in to the PSU... or a bad batch...
Your computer probably pulls like 550 max, so it was probably just a bad supply.  @SnaKz
RIP
Linux "nerd".  If I helped you please like my post and maybe add me as a friend :)  ^_^!
Even if it is too weak it wouldn't explode.
Send that shit back!
Like watching Anime? Consider joining the unofficial LTT Anime Club Heaven Society~ ^.^
Wattage should be fine, but a bit close. Not really sure what happened, was there lightning? Did you do something when it happened? Did it ruin your parts?
I would say, that a 550W high quality PSU would be enough, even if you were to overclock the CPU.
Did it explode, just like that, at the first start-up? .__.
Request a RMA from Corsair on corsair.force.com
Don't even think about trying to start the computer again with that PSU, unless you want to damage your other parts.
Oh, Corsair, you shouldn't forget your videos, even very old ones...
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
Not being enough is outta the question.You can't pull more than 450watts on full full load.
Just send it back for RMA and hope that nothing else got fried :|
 i5 3570k @4.all over the place || CM Hyper TX3 Evo || ASRock Z77 professional-m || 8GB G.SKILL Ripjaws Z 2400mhz CL10 || MSI GTX770 2GB OC'd 1280/3825mhz || ADATA SP900 128GB || Fractal Design Arc Mini R2 || Logitech G502 || Audio Technica ATH-M50
A spy is always better than a ninja!See burn notice. EVERYTHING is just a number!
RMA it, it was a defective one.
sudo chmod -R 000 /*
Everything worked fine for like 3 weeks, and then out of the blue poof.
I nearly shit myself when i heard that.
I hope nothing else got fried, fingers crossed.
B-BUT!
Still, even that site you linked doesn't really tell us why it's supposed to blow up... it was just a defective unit, it happens to all the best psus...
B-BUT!
One of the PSU videos where Logan doesn't actually look inside the PSU himself to see the components. Should be a sign. The RM PSU's are overpriced and overrated. If they were cheaper then they would be worth the hype and the sacrifice in quality, but not at the numbers they're at now.
"Rawr XD"
Rm doesnt's suck and also the normal font and size is enough
You're really going to say that when I just provided evidence that they do, and this is a thread about an RM blowing up?
"Rawr XD"
Corsair RM use cheap chinese capacitors, one of them probably popped.
Just because its not as good as something else doesnt mean that it sucks...These things can happen to any PSU even the best quality ones..
I just disagree on the part that it sucks..Its just not as good as some competition
"You can get more of what you want with a kind word and a gun than you can with just a kind word." -- Al Capone.
They're just too overpriced for whats in them, and so overrated just because they were advertised like hell.
"Rawr XD"
kk... I havent said otherwise
RMA that bitch. It should never do that. A good 600 watt would have been able to hold it's own with those components... With luck nothing else go killed.
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 3x 1TB Seagate Barracuda (dumping ground), 3x 8TB WD White-Label (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
Well according to Jonny guru the capacitors in the RM series aren't good, this result shouldn't be too surprising to be honest. If you can, opt for corsair to pay you out or give you something besides an RM series - CX would be a better option.
The most common result of insufficient wattage is a paperweight that looks like a PC
The secondary capacitors are cheap Chinese ones, which had problems with PSU blowing up and failing a few years ago.
I would stick to EVGA supernova, cooler master v series, xfx and seasonic off course ;-)
Hardware: Intel I7 4790K 4Ghz | Asus Maximus VII Hero Z97 | Gigabyte 780 Windforce OC | Noctua NH-U12P SE2 | Sandisk Extreme Pro 480GB | Seagate 500Gb 7200Rpm | Phanteks Enthoo Luxe | EVGA Supernova G2 850W | Noctua NF12 | SupremeFX 2014 | Patriot Viper 3 16GB.
Gaming Gear: Cooler Master TK Stealth | Sennheiser PC350SE | Steelseries Rival | LG IPS23L-BN ' 5ms | Philips Brillians 144hz
Of course that's the good stuff, my recommendation was based on OP's limited situation :)
