MSI direct audio or Steelseries usb amp dongle
full_force1986
Hi I am wondering if I should be running my headset through the usb dongle that came with my steelseries 9H or should I connect the direct audio power cable supplied with the motherboard and use the on-board rear connectors?
Motherboard is a MSI gaming 5 and headset is a steelseries 9H?
Thanks for your help.
CPU: 4690k - 4.5@1.29v  GPU: GTX 780ti - core +100 / Mem+350 Motherboard: Asus Z97-A  SSD: 256Gb 840 Evo HDD: Seagate Barracuda 1TB  RAM: Corsair Vengance Pro 2x4Gb  Case: White H440  PSU: RM850  Cooling: NZXT Kraken X60
try what he said ^^^  then report back to us and let us know what you think.  I have heard rumors that unless it is a really cheap usb implementation then the usb mic stuff sounds better than using the mobo's mic in.
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
To revolutionary, need to base choice off opinions of others.
Well I tried both and I think it sounds better from the usb thing.
I will just use the usb dongle and when I get a set of speakers ill use the rear panel for those.
