First 4790k review, overclocking issues!
So hexus.net published their review on the 4790k and they run into some pretty major overclocking issues.
It is reasonable to assume that overclocking plays a big part in considering this processor. However, our engineering sample exhibited unexpectedly poor overclocking potential, barely stable at an all-core 4.4GHz. We're awaiting retail samples before doling out advice on just how high the average Core i7-4790K is likely to go: stay tuned for that.
A word or two about temperatures: Intel says it is to use the same processor-in-box (PIB) cooler for this chip as for the 4770K. We used just such a heatsink during regular testing and found that, due to the extra power consumption generated by higher voltages, the Core i7-4790K ran hotter, at an average of 88C, compared to 78C for the older Haswell processor.
Hopefully this is just an issue with the specific sample and not of the whole Devil's Canyon series.
Source: http://hexus.net/tech/reviews/cpu/70473-intel-core-i7-4790k-devils-canyon-22nm-haswell/
https://linustechtips.com/topic/161128-first-4790k-review-overclocking-issues/
I'll stick with my 4670k @ 4.6 thank you very much...until Broadwell.  :)
Not everyone is as lucky as you in the silicon lottery so yeahhhh :D
CPU: i7 2600 @ 4.2GHz  COOLING: NZXT Kraken X31 RAM: 4x2GB Corsair XMS3 @ 1600MHz MOBO: Gigabyte Z68-UD3-XP GPU: XFX R9 280X Double Dissipation SSD #1: 120GB OCZ Vertex 2  SSD #2: 240GB Corsair Force 3 HDD #1: 1TB Seagate Barracuda 7200RPM PSU: Silverstone Strider Plus 600W CASE: NZXT H230
CPU: Intel Core 2 Quad Q9550 @ 2.83GHz COOLING: Cooler Master Eclipse RAM: 4x1GB Corsair XMS2 @ 800MHz MOBO: XFX nForce 780i 3-Way SLi GPU: 2x ASUS GTX 560 DirectCU in SLi HDD #1: 1TB Seagate Barracuda 7200RPM PSU: TBA CASE: Antec 300
The Article is from WCCFtech...I would remain skeptical and wait for more reliable sources to confirm this.
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
just because they changed TIM doesn't magically mean every 4790k will hit 5 ghz,
Idk why people got their hopes up so far.
Because they were comfortable enough to raise the out of the box speed to 4.0. So they must have sonehow improved the process, or have binned the chips higher, so more chance of a better overclock by default
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
I think what's more likely is that the new TIM made all the previous bad chips suddenly able to go much further, but didn't do much for the ones that were already really good. So when it came down to altering clocks, they felt comfortable upping to a 4GHz base cutting into the increased overhead. This would mean that people would achieve higher overclocks in general (say 4.4/4.5 than 4.2/4.3) but it would be less substantial an overclock compared to the base clocks than previously.
This may also be possible, but you have to know thar even dellided haswels werent guaranteed to hit 4.5, so something had to change
It's more likely that with cooler temperatures they saw fit to up the clock speeds.
@Faa or @ProKoN has a list of like 1000 haswell overclocks, most of em hit atleast 4.4 from what I've seen if I remember right.
refer to one post up ;)
editted my post too
Voltage looks similar to my 4770k for those speeds. I am at 1.15 for 4.3, 4.5 at 1.22v.
This is what concerns me.
"A word or two about temperatures: Intel says it is to use the same processor-in-box (PIB) cooler for this chip as for the 4770K. We used just such a heatsink during regular testing and found that, due to the extra power consumption generated by higher voltages, the Core i7-4790K ran hotter, at an average of 88C, compared to 78C for the older Haswell processor".
So basically 1.3v is still going to be "safe" most likely (just like a 4770k)  and these are just high binned chips so you don't get 4.1-4.3 clunkers on water cooling at 1.3v, and if you got lucky on a 4770k you basically got a "devil's canyon".
Good for enthusiasts I guess, but not what I was hoping for. :(
​Also anyone that runs these on a stock cooler = insane.
CPU:24/7-4770k @ 4.5ghz/4.0 cache @ 1.22V override, 1.776 VCCIN. MB: Z87-G41 PC Mate. Cooling: Hyper 212 evo push/pull. Ram: Gskill Ares 1600 CL9 @ 2133 1.56v 10-12-10-31-T1 150 TRFC. Case: HAF 912 stock fans (no LED crap). HD: Seagate Barracuda 1 TB. Display: Dell S2340M IPS. GPU: Sapphire Tri-x R9 290. PSU:CX600M OS: Win 7 64 bit/Mac OS X Mavericks, dual boot Hackintosh.
Tbh 1.22v isn't even high at all (actually quite good for 4.5 I think)
I'll be getting a 4790k soon, hopefully it hits close to 5, that'd make the enthusiast side of me very happy :D
Honestly I'd be comfortable using 1.5v maybe, because even if it dies, the chip doesn't really cost much in the first place, compared to the 3930k I have now.
I guess getting a really expensive chip puts a new perspective on less expensive ones
CPU: AMD Ryzen 7 3700X - CPU Cooler: Deepcool Castle 240EX - Motherboard: MSI B450 GAMING PRO CARBON AC
RAM: 2 x 8GB Corsair Vengeance Pro RBG 3200MHz - GPU: MSI RTX 3080 GAMING X TRIO
It's expensive for others I suppose, it's still quite a bit of money, but 2 4790k's is almost what my single 3930k cost new, so it's not "as bad" I suppose.
Honestly IDK why I bought 2011 in the first place, I barely even use it :/
:D we get it. you`re shitting money, stop bragging
"You know it'll clock down as soon as it hits 40°C, right?" - "Yeah ... but it doesnt hit 40°C ... ever  😄"
GPU: MSI GTX1080 Ti Aero @ 2 GHz (watercooled) CPU: Ryzen 5600X (watercooled) RAM: 32GB 3600Mhz Corsair LPX MB: Gigabyte B550i PSU: Corsair SF750 Case: Hyte Revolt 3
If your hobby is computers it's no less than you would spend on lessons in another hobby like dancing or something over the course of a year and it'd last much longer. The 3930K should be good for another 2 or 3 years or more.
Where am I bragging...?
The source is actually overclock.net forums. WCCF just reported it first. Check out the competition live. http://hwbot.org/competition/intel_occ_computex14/ In the air/liquid cooling category the fastest frequency achieved is 5.4 GHz.
My PC: CPU: Intel Core i3 3220, MB: ASUS P8P67 LE, GPU: Palit Jetstream GTX 670, RAM: 4GB 1333mhz DDR3, Storage: 750GB Hitachi, PSU: CoolerMaster G650M 80+ Bronze, Cooling: Coolermaster Hyper 212 Plus, Case: Multirama, Display: Acer x229w 22" 1680x1050, Keyboard: Logitech K120, Mouse: Steelseries Kinzu v2, Sound: Logitech 2.1 system
  • 3 months later...
Well I barely got my 4790K stable at 4.7GHz, to get there I had to use voltages higher than what I would usually be comfortable with (1.377V).
I'm not sure if I just got a crappy chip or if they are all like that. I have to complement the stock TIM, at that voltage using a Kraken X60 with stock fans and Arctic Silver MX-4 thermal paste. Tempretures never got higher than 85C when running OCCT.
how dare you necro this thread
Listen if you care.
