Need help searching for a dvd player with specific features
Solved by adm0n,
Just looking for "portable blu ray player" brings up a plethora of devices that all basically do what you want.
But unless that isn't feasible for your use case, I'd really much rather go with a usb-c blu ray drive. That way you can watch the videos on any laptop, that is almost sure to have a better screen and better battery life. And for modern laptops you can also get a USB-C power bank to increase the battery life even further. Most portable blu ray players will need AC power.
