High static pressure 80mm pwm fan, but with low Db
SansVarnic
Looking for a decent suggestion for a high static pressure 80mm fan, but with low Db.
Most I find have a 60+ Db. Maybe I am looking in the wrong places.
Reputation is a Lifetime to create but seconds to destroy.
 CHRISTIAN MEMBER
Arctic P8 or P8 Silent?
Arctic P8s for sure, cheapest and have about as good of pressure as you will find that small.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
Thanks, looking to replace the current 80mm in my server that doesn't sound like a jet on take off.
 CHRISTIAN MEMBER
@Levent @Skiiwee29
Damn those are quiet fans.. looking at the p8 max (has PWM the other variant seem to use 3pin), if I converted the sone correctly that is only <23dB
This will work.
 CHRISTIAN MEMBER
IDK what server you have, but I'd try spinning the included fans slower if you haven't already.
Think I got a P8 in Frog.  Deffo some 80mm arctic variant
 With all the Trolls, Try Hards, Noobs and Weirdos around here you'd think i'd find SOMEWHERE to fit in!
Some high pitched off brand fan, loud even at 50%.
 CHRISTIAN MEMBER
thrmalright has 80mm fans too
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
Posted (edited)
Yes this is correct. So do a lot of other companies. Do you have a contributable suggestion?
E: apologies that sounded snippy, don't make replies after just waking up. 🙄
Edited by SansVarnic
 CHRISTIAN MEMBER
