Need power source options for powerful fans
It's probably 6300,0 rpm or some mistake in description.
But anyway for both fans... You can power them by connecting them directly to the ATX power supply.
Take out the 12v and ground wires from the connector, and connect them to a molex or sata connector. Molex would be better, it's rated for 5A of current, your fan says it can do 4.35A max. SATA is only good for 4.5A of current.
You can control the speed through the pwm wire just like with any other fan, connect that wire and the ground wire (duplicate it if needed) to the fan controller or the motherboard fan header.
And there's more powerful fans available than that... for example this Sanyo Denki 140mm fan runs at up to 7600 rpm and eats up to 55 watts : 9GV1412P1G001
or this delta model that goes up to 7400 rpm and 44.5 watts : PFR1212DHE-SP00
