Need help picking a processor to pair with a 4070
Go to solution Solved by EMUMSC,
Finally after careful consideration, we went with an
Intel core I5 14600K
A Gigabyte RTX 4070 OC
A gigabyte B760 Gaming X MBD
2TB Aorus Gen4 7300 SSD
32 Gigs of DDr5 5600Mhz Ram
A deep cool AK620 Zero Dark
A Silverstone Viva 650W PSU
Any advice on how i should set up security on this PC. It is gonna be used by about 4 people. But we need to limit access to these people. But we would prefer to use a complex password with like access security keys so we can authorise them when we need to. Any idea how to set this up.
Also thank you guys for helping me set this up ❤️
Budget (including currency): 615,000 LKR
Country: Srilanka
Games, programs or workloads that it will be used for: Video editing, Rendering, and multitasking these. ex: After effects, Premier pro etc
I believe that I have made 2 possible quotations with my budget, but I'm contemplating whether to go with more Vram since the memory bus is small and whether it will have any impact on raw performance. and I tried to get a 4070 but it's way above our budget.
any help is appreciated and thanks in advance!
An AIO on this build isn't worth it. Get a 2 tower air cooler, like a thermaltake peerless assassin or phantom spirit.
Also, the 990 is a quality drive, but it is a poor value for money. Look at cheaper options.
3rd, avoid RGB ram and avoid buying 2 seperate sticks, get a cheaper kit that is atleast (2x16GB) 6000Mhz and CL36.
Also, the motherboard seems a little expensive, look for cheaper well reviewed options that have the features you want
Then try to fit a 4070 into the budget.
I might be experienced, but I'm human and I do make mistakes. Expand for common PC building advice, a short bio and a list of my components and other tech. I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need.
Common build advice: 1) Buy the cheapest (well reviewed) motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother. 7) "Bottlenecks" rarely matter and "Future-proofing" is a myth. 8) AIOs don't noticably improve performance past 240mm.
useful websiteshttps://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
He/Him
I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 3 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). While I believe I have an decent amount of experience in spec’ing, building and troubleshooting computers, keep in mind I'm not an expert or a professional and I make mistakes.
Favourite Games of all time: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii
Main PC: https://uk.pcpartpicker.com/user/will0hlep/saved/NByp3C
Secondary PC: https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P
TrueNAS Server: https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C
Laptop: 13.4" ASUS GZ301ZE ROG Flow Z13, WUXGA 120Hz, i9 12900H, 16GB DDR5, 1TB NVMe SSD, 4GB RTX 3050 Ti, TB4, Win11 Home, Used with: 2*ThinkPad Universal Thunderbolt 4 Dock, Logitech G603, Logitech G502 Hero, Logitech K120, Logitech G915 TKL, Xbox Elite Wireless Controller Series 2, Logitech G PRO X Gaming-Headset (with Blue Icepop in Black), {specs to be updated: two monitors}
Other: LTT Screwdriver, LTT Stubby Screwdriver, IFIXIT Pro Tech Toolkit, Playstation 1 SCPH-102, Playstation 2 SCPH-30003, Gameboy Micro Silver OXY-001, Nintendo Wii U WUP-001(03), Playstation 4 CUH-1116A, Nintendo Switch OLED HEG-001, Yamaha RX-A4A Black AV Receiver, Monitor Audio Radius (4*90s, 1*200s, 2*270s, 1*380s), TP-Link TL-SG105-M2, Netgear GS308, IPhone 14 Pro Max 128GB Space Black, Secretlab TITAN Evo (Black SoftWeave Plus Fabric), 2*CyberPower BR1200ELCD-UK BRICs Series, Samsung 40" ES6800 Series 6 SMART 3D FHD LED TV, UGREEN USB 3.2 Gen 2 10Gbps M.2 NVMe SSD Enclosure, SABRENT 3.5" SATA drive docking station
3 hours ago, EMUMSC said:
This is the answer you are looking for:
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
For productivity not gaming though?
System specs:
GPU: Sapphire AMD Radeon RX 7800 XT NITRO+ [1050mV, 2.8GHz core, 2.6Ghz mem]
Case: 5000D AIRFLOW
PSU: Corsair RM850e
RAM is the standout problem! That is a single stick of slow clock speed, appalling latency RAM: Try to find 2x16Gb DDR5 ideally 6000MT/sec CL30 for AM5. Even if you have to compromise on latency - which isn't as much of an issue for non-gaming use, but try to get the 6000 speed and then 2 sticks with 32Gb or more is really important for video editing too.
Motherboard seems steep - Asrock B650 RS Pro is about half that price normally! Sheck your local B650 boards, sort by price and see if any of the cheaper ones are well reviewed on one of the Hardware Unboxed B650 roundup reports (on YouTube).
Hot climate + heavy CPU+GPU rendering, I'd consider an AIO as it allows you to separate the CPU cooling from the GPU; so you can cool the CPU on the intake rather than using the hot air coming out the back of the GPU (painful personal experience of this).... that said, the 360 is crazy overkill.... the AF iii 280 provides almost the same peak cooling, just less heat-soak capacity or the AF ii 280 that I have is apparently good for everything up to the LGA1700 i7/i9 CPU's (i.e. any AM5 CPU).
The 16Gb of VRAM on the 4060Ti will be partly nerfed due to the comically small memory bus, but at least it will be there.
Alternatives: I assume with those apps you need CUDA (nVidia) support, so the Radeons with more VRAM won't appeal.... I'll let a video-editing specialist confirm if it is better to get a 4060Ti or something like a 2nd hand RTX3080 12Gb (384bit vs 128bit memory bus)... and that should be WELL within that LKR260500 (USD 800?!?) budget.... might even consider a 3080Ti (also 12Gb) or RTX3090 with 24Gb VRAM (if that will help with the software you're using).
Any of those would give you 3x the texture fill and between 50% and 100% more processing capacity (depending if the code leverages the newer architecture).
Downside is double the TDP / heat output.
https://versus.com/en/gigabyte-geforce-rtx-4060-ti-gaming-oc-8gb-vs-nvidia-geforce-rtx-3080-12gb
My workstation/gamer: Ryzen9 5900X@5Ghz, AC Freezer2 280mm AIO, ASUS TUF X570PRO, RTX3080Ti FE, 32Gb TridentZ DDR4-3600C14, M.2 1Tb WDSN850, M.2 1Tb WDSN550, 2x 8Tb WD80EFAX, Corsair HX850, LianLi O11 Air Mini + 3x NF-A14's, Gigabyte M27Q (27"/1440P/170Hz), Asus PA248 (24"/1200P/60Hz), Dell WFP2408 (24"/1200P/60Hz), G815 kbd, G502 mouse, Sony WH-H910N, ModMic Wireless.
Country: Srilanka
Intel CPU tend to offer better performance for this use case.
I totally agree, but we live in a warm country and the computer would be used outdoors, so that is why we went a little overboard with cooling
well we are using 2 sticks of 16GB ddr5 memory on our system
The problem is that our country is facing heavy tax burdens and the extreme demand and low supply have skyrocketed the price to an extreme high. and we are really finding it hard to get hold of 3080s and even 4070s.
I did check on that, but z790 motherboards are almost twice the price if a b650.
Any thoughts on an Intel core I5 14600 and a B760? or should i stick with my original combo, a R9 7700X and a B650
UPDATE
we decided to extend our budget to around 680k. and this is our current quotation
we are still deciding on whether i should go for an Intel core I5 14600 and a B760? or should i stick with my original combo, a R9 7700X and a B650?
Even in a hot climate a 360mm AIO is overkill imo. I'd personnally still get a tower cooler, but if your heart is set on an AIO, I'd recommend you drop to a 240mm and save a kittle money.
50 minutes ago, EMUMSC said:
What is the latency of the RAM? Is it CL36? CL40? CL30?
Also, the NV2 should be avoided. Those drives are made from a lucky dip parts bin. What other options are available to you in terms of SSDs?
He/Him
1 hour ago, EMUMSC said:
UPDATE
RAM is slow. Target 5600-6000MHz CL28-30.
Desktop: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - RMx 750 W 80+ Gold - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro Corsair K70 LUX browns - PC38X - Mackie CR5X's
Current build on PCPartPicker
Posted (edited)
Ideally an i7-14700 on a B760 motherboard for content creation. The i5-14600 is not generally available, I believe it is an OEM part. But one could go with an i5-14600K or i5-14500 on a B760 motherboard.
See https://www.pugetsystems.com/labs/articles/14th-gen-intel-core-processors-content-creation-review/ for relevant benchmarks.
Edited by brob
Typos on CPU models.
the ram latency is C40. there is a 5600 c36 2x16 kit for 11000 rs extra. is it worth the price jump?
as i said lock stockage has us choosing between the kingston and a 990EVO which is too overkill for us
On 3/8/2024 at 3:03 PM, brob said:
Ideally an i7-14700 on a B760 motherboard for content creation. The i5-14600 is not generally available, I believe it is an OEM part. But one could go with an i5-12600K or i5-12500 on a B760 motherboard.
On 3/8/2024 at 12:11 PM, EMUMSC said:
UPDATE
sorry, its an I5 14600K. since i am looking towards content creation many people suggested going with an INted. so just wanted to check on this. and i have no past experience with B660 and b760 mbds. so is it worth the switch?
Given that an SSD upgrade would be a very simple operation, would you consider buying it seperately and installing it yourself? That would allow you to get better value SSD than a 990, without having to choose an unreiable NV2.
So you'd effectively be paying $169 for 32GB of 5600Mhz CL36. That seems like a complete rip off. Given that installing RAM is also very easy, and you'll almost certainly be able to find better value kits, I'd again suggest buying that seperately.
He/Him
well we are kind of in a rush and so we need to manage with any locally available stocks. its crazy spending almost 900usd for a rtx 4070, but thats the reality. :')
Check the link in my last post. If the principal use is Adobe content creation products an i5-14600K generally outperforms the 7700X.
yeah we do heavily rely on adobe programs. so ig the i5-14600k is the best bet. any thoughts regarding the Motherboard for the card?.
image.thumb.png.e29f12af8da62cf56ab043787eb7b23b.pngimage.thumb.png.3e61933609dc9e96293b754d95a2ac47.pngimage.thumb.png.f136c706c92bb38927e868a51bd14b6e.png
The MSI B760M-A WiFi DDR5 would be a good choice.
I also found a I5-14400F for around LKR 80,000. Would this cause a bottleneck?
The i5-14400F lacks an iGPU so Quick Sync would not be available for encoding acceleration.
Are the i5-14600K and i5-14500 not competitively priced?
Budget (including currency): 650,000 LKR
Country: Srilanka
Games, programs or workloads that it will be used for: Primary editing Rig for, using Adobe products
Building a new editing Rig, mainly focusing on Adobe applications like premiere pro and after effects.
The rig has 32 GB of Ddr5 5600 memory, an 850w PSU
The CPU options are either
AMD R7 7700X RS.110,000 or a R5 7600x Rs.80,000 with a B650 MBD
Or
Intel I5 14600K Rs,110,000 or an Intel I5 14400F Rs.80,000 with a B760 MBD
We are on a budget constraints, and or country as a whole is out of stock of brand new peripherals. so just wanna know how each processor pairs up to each other for our workload.
Screenshot_2024-03-08-13-06-09-686_com.google.android_apps_docs.thumb.jpg.d03027d3a9198b75a68f3b30aadd4bd8.jpg
14600kf would be best for editing stuff. More gaming would be r7 7700 or r5 7600 (no x, it costs too much for small performance gain)
Can we see the whole build?
Personally I wouldn't go for either the R5 7600X or i5 14400F as it is not recommended as a good pair in gaming on a bottleneck calculator. If the only options you have left are the R7 7700X or i5 14600K then I would go for the i5 14600K.
Bottleneck calculators don’t work. But you got to the right answer on accident. For gaming (generally) amd cooks intel, but for productivity intel’s ten brillion trillion million cores are better
Those are worthless.
I got with bottleneck calculators for my first line of research, then I look at yt vids
