Are my Front panel fans efficient or not?
tls123
So, I have a question about my fans. I am unsure if the fans are efficient/productive with the way they are setup, I am unsure if I put fans side by side, would they add their intake force or something or would it just further inhibit the airflow? the metal between the two fans are just holes and I am unsure if the extra fans are just causing blockage to the airflow and just restricts it's entry. Below is a drawing I have to illustrate the fan positions
A few questions to get a better understanding,
What do you mean side by side?
What case is that?
Are you sure the side bits are intake, the fans look almost flush to the mesh and the sides look pretty solid even though theyre textured like vents?
Do you have a full picture of the PC to show other fans
And beyond that some advice, having fans pointing into the case will never restrict airflow, fans are able to move much more air than ambient pressure can add when your case is negatively pressured. Therefore, having fans at all, even if weak will always add more air to the case!
System specs:
GPU: Sapphire AMD Radeon RX 7800 XT NITRO+ [1050mV, 2.8GHz core, 2.6Ghz mem]
Case: 5000D AIRFLOW
PSU: Corsair RM850e
It may not be the best design, but if the CPU and graphics card load temperatures look reasonable I wouldn't worry about it too much.
As TatamiMatt said we can't really see if the front fans are behind the side intake or infront of it. We also don't know what components you have. I have computer case from 2007 with only side intake and a single exhaust fan at the back that works alright for my Ryzen 3800x.
CPU: AMD Ryzen 9 3950X   Motherboard: MSI X570 Gaming Edge Wifi   Case: Deepcool Maxtrexx 70   GPU: RTX 3090   RAM: Corsair Vengeance LPX 3x16GB 3200 MHz   PSU: Super Flower 850W
seems fine to me. if the fan is on the inside of the case. even then should be fine is it the best no. but from best to what you have maybe 1-2c at best so🤷‍♂️
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
