There is a common notion in the community that graphics card overclocking is dead - It's not dead
Overclocking now days is different than the traditional pump more voltage for higher frequency and you are done though you can still do that if you want but it's not the most effective way to do so in the day and age of sophisticated boost algorithms.
To get significant gains you also need to learn how boost works and use that to your advantage,
For example on NVIDIA GPUs the boost clock rises the colder you go as long as there is headroom to the power limit.
Not only the boost clock rises on colder temperatures, but the overclocking potential rises as well on top of the increased boost clocks.
Another thing is to find out the bottleneck on your graphics card - If the VRAM is bottlenecking the GPU you should overclock the VRAM first then the GPU.
Here is an example from Cyberpunk 2077:
Before:
After:
From 64 FPS to 76 FPS = A performance increase of 18%
Notable differences:
Temperature: 59C vs 50C
GPU: 1965MHz vs 2130MHz
VRAM: 4001MHz vs 5000MHz
Also i got the highest GTX 1660 Geekbench compute score in the world:
https://browser.geekbench.com/v5/compute/6238503
So no, graphics card overclocking is not dead.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
https://linustechtips.com/topic/1487108-gpu-overclocking-is-not-dead/
I've always interpreted to more mean the shift in focus. With the advent of boost technologies it is less about "how far out of spec can I push this thing" and more "how cool can I get it such that GPU Boost will boost as high as possible / as high as I want". I guess it took the "over" out of overclocking, since for all intents and purposes it is intended functionality nowadays given power and thermal headroom.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
You can overclock on top of the boost to get even better gains...
Nice job!  I was once #5 for the R7 1700 OC for a long while when that chip came out, last I looked I was in top 12 but I kind of left OCing behind lol (just ran out of time to really get into the weeds of it).
But this post gives me the itch lol.  I havent tried OCing on my RTX 2060 or RX 6700 XT yet at all.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
I used to be #1 on most GTX 1660 benchmarks, but at some point my competitors found new black magic tricks to boost their scores even at lower clock speeds than i was running -_-
I dont know enough to get further than I did, mine was very shadetree and luck of the lottery (I have 5 1700's overall and 2 of them are just flat out OC performers.  Its like they were intentionally binned as 1700s but could have been 1800x's no problem (at stock voltage I can keep them at 4.0 constant etc)
Keep up the lords work!
Sounds like AMD GPU overclocking. On there if you run a benchmark 6 months after someone else you get an extra 2% performance for free.
If you know what you're doing you generally can get some pretty good performance increases. I know my 6900 XT on daily stable settings is 12% faster than stock, partially because there was slider headroom, partially because BIOS modding AMD cards to get an unlimited power limit is pretty easy and RDNA2 is very power limited.
There aren't many cards than have headroom that you're likely to notice anymore though. The 6650 XT I messed with recently got an extra 5% performance total from an overclock, the 3080 I used to had even on water was barely 5% faster than at stock. Part of the problem is that AMD and Nvidia have been locking down overclocking so much over recent years, other part is that the boost algs have gotten everything pretty close to maxed out at ambient already that getting an extra 100MHz on the core clock and 500Mbps on the memory is about all you can hope for (at least on high end cards with what I'm used to, not really that sure about mid range).
Still though, good results. I think all that's left to do is take the card colder. LN2 anyone?
A chiller would be fun to use,
Should give good results and is easier and cheaper than DICE or LN2.
1660 is bandwidth starved with it GDDR5, that's why you see significant gain when you overclocked the memory.
The refreshed 1660S with faster GDDR6 able to match 1660 Ti even with lower core count. 🤔
Yep, overclocking is not dead. Pushing the power limit on my FE 3080 Ti and bumping both the core clock and memory clock to something like +120/+1100 works great and at that point I more just hit the power limit. Since its under a water block, the temps are fine. And doing both an OC and an undervolt stabilizes the boost so its not bouncing around so much at the top of the boost.
One of these days I'll get brave and try my hand at some shunt modding. Would love to pump some more power into this thing and see what it can do. Right now, very limited by the 400W max.
Zen 3 Daily Rig (2022 - Present): AMD Ryzen 9 5900X + Optimus Foundations AM4 | Nvidia RTX 3080 Ti FE + Alphacool Eisblock 3080 FE | G.Skill Trident Z Neo 32GB DDR4-3600 (@3733 c14) | ASUS Crosshair VIII Dark Hero | 2x Samsung 970 Evo Plus 2TB | Crucial MX500 1TB | Corsair RM1000x | Lian Li O11 Dynamic | LG 48" C1 | EK Quantum Kinetic TBE 200 w/ D5 | HWLabs GTX360 and GTS360 | Bitspower True Brass 14mm | Corsair 14mm White PMMA | ModMyMods Mod Water Clear | 9x BeQuiet Silent Wings 3 120mm PWM High Speed | Aquacomputer Highflow NEXT | Aquacomputer Octo
Test Bench:
CPUs: Intel Core 2 Duo E8400, Core i5-2400, Core i7-4790K, Core i9-10900K, Core i3-13100, Core i9-13900KS
Motherboards: ASUS Z97-Deluxe, EVGA Z490 Dark, EVGA Z790 Dark Kingpin
GPUs: GTX 275 (RIP), 2x GTX 560, GTX 570, 2x GTX 650 Ti Boost, GTX 980, Titan X (Maxwell), x2 HD 6850
Bench: Cooler Master Masterframe 700 (bench mode)
Cooling: Heatkiller IV Pro Pure Copper | Koolance GPU-210 | HWLabs L-Series 360 | XSPC EX360 | Aquacomputer D5 | Bitspower Water Tank Z-Multi 250 | Monsoon Free Center Compressions | Mayhems UltraClear | 9x Arctic P12 120mm PWM PST
Just don't do the liquid metal method, the piggyback method is better.
