Is it worth to buy a custom 8 Pin EPS cable?
Solved by RONOTHAN##,
Usually they come as part as a bundle with other cables (I just buy the kits, never do any of the more custom wor for them), so might as well use it and wire it up, but I personally wouldn't buy one unless I needed one.
If you're doing full custom sleeved cables though (I'm talking things like the Cable Mod configurator or doing it by hand), you probably care enough about aesthetics that it would matter to you, even if it's only slightly visible.
