Not sure where to start - Copying files to system from Windows/Mac/Linux over network while traveling
11 minutes ago, justanoobhere said:
My thought was to partition the 4TB HDD into 1.5TB NTFS, 1.5TB HFS, and 1TB Ext4 so that every file system has a compatible partition to copy to/from. The 2TB HDD would be split 1TB NTFS and 1TB HFS to store essentials in case the 4TB drive fails.
I'm just not sure what OS or software I need to use in order for the family members to be able to access and write/read files over the network, especially while they're traveling.
The filesystem for the nas won't matter, so Id make it all ext4 or native os for the server.
Software wise, Id go with nextcloud here. Pretty easy to use, nice web gui and good sync client for windows/mac/linux
14 minutes ago, justanoobhere said:he most important need they have is for the backup location to keep their "date created" and "date modified" information about their files when copied back and forth.
They've tried doing this with external drives but for some reason it hasn't worked (my guess is filesystem differences, e.g. FAT instead of HFS).
This is likely due to the waay the files are being copied, if you use somethinglike robocopy or rsync you have a option to keep the dates on the files. I think linux + windows + osx can all use the date/time on fat32 and exfat
