Does Resolution Affect Processor Temps?
By
Taintedmind
in Displays
in Displays
Solved by xAcid9,
55 minutes ago, Taintedmind said:I'm pretty sure it doesn't, but do higher resolutions affect CPU/processor temps?
Depend, if you're CPU bound at lower resolution, going up the resolution might shift the bottleneck to GPU thus making the CPU do less work so less heat.
Xxu ·
Posted in Servers, NAS, and Home Lab0 -
2
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Posted in Servers, NAS, and Home Lab3 -
Sveeno ·
Posted in LTT Releases8 -
4
play_circle_filled
Latest From ShortCircuit:
