USB c powerbank for laptops
A quick search shows that anything under 65w will only charge when the laptop is turned off. I'd personally look for a 100w charging solution; they're a little more expensive, but I think it'll be far more useful. I've linked a few, as well as the thread on Reddit which might be a useful read to you.
https://www.theverge.com/2019/5/1/18410552/laptop-portable-batteries-high-wattage-usb-c-charger
https://jgotech.com/products/zseries-100w-pd-26800mah-usb-c-pd-power-bank
https://www.newegg.ca/all-nighter-aohi-universal-30000-mah-power-bank/p/39G-019H-00002
35 minutes ago, Alex Atkin UK said:Thunderbolt doesn't mean you can charge through that port, they are entirely different things.
Thunderbolt, charging and USB can all use the same port but they each require dedicated hardware in the laptop to do it.
Its highly unlikely any 300W laptop will support charging as you don't want to be in a situation where you are powering the laptop externally and the other alternative would be for say the laptop to throttle down to 65W performance so it CAN charge and run at the same time - it wouldn't exactly be a popular decision.
Though personally I could find that useful, I think it would be really quite hard for the manufacturer to tweak higher performance hardware to throttle down that low. My gaming laptop already throttles down to "omg this is so bad" performance levels on battery as it is and still runs out in 2 hours desktop use.
I really wish people wouldn't state things when they don't know the answer. If you don't know, just say nothing. Don't state things you think might be true as if they're fact.
