I got an MSI Reference RX 6900XT to 9c WITHOUT AIO or a water block.
GetTheClicker
My build is up high because the previous one did not survive well on the floor. The wife tripped and spilled soda all over the top exhaust fans and my toddler tried to clean the side panel window with a rough rag that was like sandpaper. So I put it up high in a corner behind 3 tv's that get a little warm. SO, I've done a little redneck engineering with a trip to home depot I made this. At the very end of the tube at the window is a 3k rpm 120mm fan that plugs directly into the wall with a converter that sucks up all the 15f degree winter air. I overclocked the card a little bit and ramped up all the fans. The warmest the GPU ran was 48c while playing Cyberpunk 2077. There was at no point over the last 2 days straight any sign of condensation. The 5950x paired with a Corsair H150i Pro didn't do so bad either.
273944163_2260827564057524_455468626209322980_n.thumb.jpg.e669854f3324b214cfa8eb81f57f0cbb.jpg274223563_2260843694055911_7823528484486254581_n.thumb.jpg.1de744027d8e70c4051eedb7ea241162.jpgTEMPS3.thumb.png.2bb9a99ccbcc7c5f7b47d76b36442e4c.png
NICE!
Main Rig:
Ryzen 5800x, ASUS Crosshair Hero VII Wi-Fi, 32gb of Corsair Vengence Pro SL 3600 CL18, MSI Ventus 2 OC RTX 3060 12gb, Corsair H115i Pro AIO cooler, Soundblaster AE-7, Beyerdynamic DT 990 Edition 600Ohm headphones, Creative Giga Speakers, 1tb ADATA SX8200 NVME SSD, 1tb Intel 665P NVME SSD, 500gb Samsung 850 EVO SATA SSD, 8tb WB Black SATA HDD, LG SATA Blue Ray Drive, Corsair CX850M PSU, Coolermaster Stryker case, ROG ARGB strips, China ARGB fans, China ARGB SSD heat sink. 🤣
HTPC:
Erying 11800 ES CPU/Mobo combo, 32GB of Corsair LPX 3200 CL16, Gigabyte 4060 8gb LP, Thermalright AXP90 full copper cooler, WD Black SN770 500gb NVME SSD, WD Black SN770 1tb NVME SSD, Crucial MX500 2tb SATA SSD, WD Blue 2tb SATA HDD, Pioneer Blu-Ray burner, Intel AX200 WiFi/Bluetooth, Seasonic 300w TFX PSU, Silverstone ML11 case. STILL NO RGB! 😭
Retro Gamer PC:
VIA C3 1000Mhz, VIA Epia PD-10000 LVDS, 1gb of Kingston DDR, PNY Geforce FX5500 128mb PCI, WD 80GB HDD, Random CD-ROM, Random 250w mini psu, Mini ITX case 🤣
None for 2 days straight. Day one I left all fans on auto and day 2 I ran everything maxed out.
That's really nice. What monitor/TV is that in the middle?
I'd still be terrified of that pipe next to my monitor and hardware though, lol
Leonidas Specs: Ryzen 7 5800X3D | AMD 6800 XT Midnight Black | MSI B550 Gaming Plus | Corsair Dominator CL16 3200 MHz  4x8 32GB | be quiet! Silent Base 802
Maximus Specs: Ryzen 7 3700x | AMD 6700 XT Power Color Fighter | Asrock B550M-Itx/AC | Corsair Vengeance CL 16 3200 MHz 2x8 16 GB | Fractal Ridge Case (HTPC)
32" Funai 1360x768 / 55" LG NanoCell 1920x1080 (Desktop) 3840x2160 (Games) / 32" Westinghouse 1360x768
60hz on the two 32 inch tv's and 120hz (1080) or 60hz (4k) on the big one.
I admit the pipe is bigger than I thought it'd be. I needed the register box to have a port big enough for the 3 intake fans on the bottom of the tower, only size in stock close enough was a 12x6 with 6" port. I can do better, make it cleaner looking, this was just a wild idea I had and didn't plan very well. Measured once and cut 5 or 6 times.
On 2/19/2022 at 7:46 PM, bmx6454 said:
what about condensation though??(which will occur)
It won't condense as long as the air coming in is constant. If the internals got cold and then warm room air was introduced, it would get condensation. But OP is feeding the same air all the time. As long as there isn't a big swing from cold to warm, it'll be fine.
It's sort of a closed system. You don't get condensation in your refrigerator because it's full of cold, dry air. Leave your fridge open for a while though and it will.
