Need advice for a GTX 1060 upgrade~
Solved by Bitter,
That's an awfully high end CPU in an awfully low end motherboard, isn't it power limit and/or VRM thermal throttling the poor thing? Right now a GPU is your bottleneck and there's nothing 'worth' the prices people are currently paying so no point in a CPU OC, but later on when you do get a better GPU that motherboard is going to be holding you back from overclocking the CPU to keep up with the new GPU.
play_circle_filled
Latest From Linus Tech Tips:
Why it Was Almost Impossible to Put a Computer in Space
play_circle_filled
Latest From ShortCircuit:
I’m kind of an iPad hater, but this is MAGICAL. - iPad Pro M4
