10x Corsair ML 120 PRO White + Corsair Commander Pro?
Solved by Novver,
Finally the Commander Pro arrived, i hooked up all 10 ML 120 fans to it, with Noctua Y splitters.
2 fans for each header (just to be safe and not overtax each connector), so 5 headers each.
Hooked it up to my current PC, not the new one since i am still waiting for the 6900XT, and it works flawlessly with iCUE.
It recognizes 5 fans on the headers, so i can control 2-2 fans with each header.
I just set it up to the highest RPM that i cant hear, which is 1300 RPM, and they do their job without a problem. I can control each 2 fans separately, so job is done. Thanks guys!
