Need help with xmp
Solved by Bob_The_Builder,
Disconnect everything that could be causing it to bluescreen, (accessories or any kind, capture card etc) and turn off XMP, run prime95 overnight and see if it spits out any errors, if it does its not XMP that's messed up its your ram or something else, see if you can isolate if its one stick or both by taking one out and doing the same thing in prime95. If one run returns no errors then it was that stick or ram, if they both still spit out errors there could be an error with both of them or some other thing is causing the issue. If it is the ram talk with the manufacture and see if they will RMA it or something similar.
