Single 2 x 8 pin PCI cable safe for RTX 3090?
Solved by Helpful Tech Witch,
On a 3090? No. One 8 pin is rated for 150, plus 75 from the slot? That's only 225. And the Fe 3090 has a 350w tdp. That's 125w more you need to makeup.
Don't take a shortcut here
Pandoroo ·
2
6
remo233 ·
Posted in CPUs, Motherboards, and Memory4 -
RTX 3090 ·
Posted in Programs, Apps and Websites1 -
7
8
porina ·
Posted in New Builds and Planning22 -
Rothinsky ·
Posted in Troubleshooting2 -
skayqz ·
Posted in Graphics Cards7
