Makes no sense...
F@H
GPD Win 2
https://linustechtips.com/topic/1310932-small-atx-cases/#findComment-14524876
10 minutes ago, CraftyVolcano853 said:
Best mini it’s cases that cab fit a full size mobo that’s under 50?:)
So are you looking for a Mini ITX case, or are you looking for a case that can fit an ATX* motherboard?
*I assume you mean ATX when saying "full size mobo".
https://linustechtips.com/topic/1310932-small-atx-cases/#findComment-14524900
So you need a mini PC with an ATX size.
Not a mini ITX but Mini Case.
https://linustechtips.com/topic/1310932-small-atx-cases/#findComment-14524912
34 minutes ago, Kilrah said:
Makes no sense...
I just read it back and starting to question if I am crazy
Yes I just worded it like a fool
Too expensive
https://linustechtips.com/topic/1310932-small-atx-cases/#findComment-14524949
https://linustechtips.com/topic/1310932-small-atx-cases/#findComment-14524990
7 hours ago, CraftyVolcano853 said:
Small ATX case’s that are portable and under £50?
Your best bet is the Phanteks P300/P300a. Any smaller than that and you start shooting up in price due low demand, or basically requiring watercooling to be any good at cooling your parts like the Thermaltake Core G3.
The other option is a Coolermaster Q500L, but you'd need to mod that case depending ont he amount of airflow you need (if it's not a gaming PC it will be okay, but if it is, you'll need to make some additional air cutouts for intake.
I've used both P300A and Q300L (the same frames as Q500L but mATX only) and the P300A is better in all ways except space efficiency.
https://linustechtips.com/topic/1310932-small-atx-cases/#findComment-14525970
If you have an ATX board, I'd recommend just selling it and buying ITX hardware. I did that and have never looked back. Portability with an ATX case is not really something that exists right now.
Current System: Ryzen 7 3700X, Noctua NH L12 Ghost S1 Edition, 32GB DDR4 @ 3200MHz, MAG B550i Gaming Edge, 1TB WD SN550 NVME, SF750, RTX 3080 Founders Edition, Louqe Ghost S1
https://linustechtips.com/topic/1310932-small-atx-cases/#findComment-14526001
