beyerdynamic Dt 990 Pro Question
Waaa
Can my motherboard onboard sound (realtek alc887) handle the beyerdynamic Dt 990 Pro?
Would probably sound like shit and/or be super quiet.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
Realtec make audio chips which convert the digital data from the computer to analogue data but they dont supply the amplifier the motherboard makers do that.
So with the information you have given I can say audio will be produced.
Most modern motherboard have good enough audio components in that most headphones will work fine.
So is you motherboard less then five years old?
Is it a normal motherboard and not some obscure server thing?
Is it not the lowest quality cheapest motherboard available?
If youve answered yes then your probably fine.
Beyerdynamic arent stupid enough to sell headphones which arnt useable for 99% of devices so there headphones are designed to work.
 if it's a  250 ohm 990 then it may be too quite. the bass can sound weak or loose. but upper regions like upper mids and treble aren't exactly hard to drive so those regions will probably be fine especially if you just need footsteps
Dude, if my ALC1220 sounded like shit then how would that 887 sound like? Your description is absolutely correct. Except for the treble part. The treble sounds muffled and weak and non-detailed without proper amp.
PM or DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
Beyerdynamic Tygr 300 R w/ Dekoni Velour as daily driver
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Keyboard > SteelSeries Apex Pro
Mouse > Steelseries Aerox 3 wireless
Mousepad > Pulsar ParaSpeed XXL
VR > Valve index kit
Read this post if you want a "gaming" headset ;)
I would really sincerely recommend the Fidelio X2HR of off amazon for about 130-140€ because they are much easier to drive and IMO sound better for almost anything you throw at them. They also have better comfort (may vary from head shape)
AKG P420 Mic
Other peripherals
That's just the dac chip though. Chances are the amp on his board is probably better than your on board. Personally my on board treble wise sounds mostly on aside from the slightly grainy sound.
Well the amp on mine should be on par and or better than his since I have the special "AMP UP" amp on it. Like, why would it be worse having a mid-tier to higher-tier mobo like I do compared to his older mobo. Either motherboards sure have a really bad QC with amp or you are just overestemating amp from motherboards.
AKG P420 Mic
Other peripherals
Maybe. Honestly unless I try your board and his I won't know completely. On my completely average motherboard it sounded mostly fine. And even some cheap dongle dacs it sounded mostly fine. The bass regions sucked and I could get maybe 50-75% of the headphones true potential . But like I said it sounded fine on those for just footsteps. I still would looks elsewhere if I was not interested in buying an amp
My mobo has Realtek ALC1150 and it can't drive my DT880 for shit. The sound is way too quiet.
DAC/AMPs:
Klipsch Heritage Headphone Amplifier
Headphones: Klipsch Heritage HP-3 Walnut, Meze 109 Pro, Beyerdynamic Amiron Home, Amiron Wireless Copper, Tygr 300R, DT880 600ohm Manufaktur, T90, Fidelio X2HR
CPU: Intel 4770, GPU: Asus RTX3080 TUF Gaming OC, Mobo: MSI Z87-G45, RAM: DDR3 16GB G.Skill, PC Case: Fractal Design R4 Black non-iglass, Monitor: BenQ GW2280
Im thinking about dt 990 80 ohm and cloud orbit s,sennheiser hd 599 im not certain tho
The 599 is a weak 6xx if I remember correctly, my friend got them many many years ago while I was on a 498 or something similar and to that it sounded peaky and bass neutral, granted this was 10+ years ago.  I would say that you should go for a 6xx over the 599 if you plan on an upgrade.  If not stick to a Beyer 80ohm or an X2HR which are both amazing while conducive to onboard.
Recommendations all come in the size of your rabbit hole.  If you want can's and nothing else, that's your end game, then go with a pair of beyer 80ohm or X2HR and you will NOT be disappointed.  If you want to make this a hobby go for something like a 6xx or beyer 250ohm.
Everything is an experience if your rabbit hole is deep enough, otherwise it's a solution and you should put your money in and go no further.
Open-Back - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100 - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
Not super exact. The 599 has a similar tuning to the 6xx in the bottom half of the frequency graph. It's sounds warm but is a brighter headphone than a 6xx. It has slightly wider soundstage than a 6xx run on a solid state easier to drive and has better imaging. In fact it uses the same drivers as the 58x. The 58x just sounds better to me for most types of music due to how the 58x is tuned. So if you can buy a 58x for the same price as a 599 I would go for the 58x
Can my realtek alc 887 handle the 80 ohm?
I SAID THIS AT THE START SECOND COMMENT. ITS JUST A DAC THE MOTHERBOARD DECIDED THE AMP.
TELL US WHAT MOTHERBOARD YOU HAVE!
lol calm down buddy didnt even see your message. msi a320m pro-e
He made a pretty big reply so hard to not to spot it lol:
Your motherboard seems to fairly new but then again, no one can know for sure untill the DT990 80ohm arrived at your door.
And ALC887 is old, really old but maybe I'm mistaken but such headphones prefers a better (external) audio gear.
My motherboard is older than 5 years old and it has ALC1150 and it's the MSI Z87-G45-GAMING and yet it can't drive my DT880 for shit.
And I also have the Marshall Mid ANC which is 32ohm and I have to enable audio boost. However, at the time when my 880 arrived at my door, I ordered an external amp just to play safe and it was the right decision as it opened my horrible eyes to enter the world of Audio Force lol
DAC/AMPs:
Why?
Why?
High impedance loads should actually perform considerably better than low impedance loads. Amplifiers are generally voltage amplifiers with limited current capabilities. Linearity should improve with high impedance loads.
is it same with dt 770
80 ohm or 32
ohm aswell
80 ohm or 32
ohm aswell
In terms of sound, unlikely.
DAC/AMPs:
Its a reasonably modern motherboard and will probably work fine with most headphones.
The beyerdynamic headphones are not difficult to use dont know why people think they are because they arnt. Old Iphones can easily run them.
Just buy the headphones they will probably work fine with no extra equipment.
Both my DT770/880 250ohm are the most difficult to drive, so yes, only the DT7/8/9 are. My Amiron Home is the most efficient with its Tesla drivers 250ohm.
He'll only know for sure when it's arrived at his door as it's not guaranteed his modern motherboard will drive it fine.
DAC/AMPs:
1 minute ago, CTR640 said:
Both my DT770/880 250ohm are the most difficult to drive, so yes, they are. My Amiron Home is the most efficient with its Tesla drivers 250ohm.
880 have a sensitivity of 101.07 dB/mW and the 770 have 94.48 dB/mW
(source) So this is the Iphone 6 headphone power output at different impedances.
They didnt test at 250ohms so we will do a worse case scenario and look at the 330ohm results.
At 330ohm the iphone can produce 3mW. So lets work out max volume this old iphone 6 can run the DT770 and 880.
The simple rule for max volume is to increase the volume by 3dB you have to double the power.
At 1mW the 880 at 101dB, we can double once to 104. We cant double again but we can go half way so a increase of 1.5dB. SO the 880 max volume on the iphone six is about 105dB.
DT770 comes out to 99dB
Now both of those numbers are low because they are 250 ohms not 330 so they would be louder. At 250 ohms the iphone six would be around 4mW so theres another one and a half deciBells
99 and 105 dB is loud thats too loud thats hearing damage loud.
So now please say again that these are hard to run headphones which are so hard that 8 year old phone has so much difficulty that it can run them so loud that you would have hearing damage. Because they arnt hard to run headphones. They are harder compared to the little white in ear thing apple gives out. But they arnt so hard they are impossible.
Also by the way the Amiron has a lower sensitivity at 97dBmW compared to the DT880 so the DT880 is easier to run then the amiron.
But back on the subject. This Beyerdynamic headphones are harder to run compared to cheap earbuds but like I said Beyerdynamic are not so business stupid they make a headphone which doent work with most devices. IF your device is reasonably modern it will have a amplifier built in capable of running 300ohms at a few milli Watts. Why because thats what the market has settled at for suitable device power. Which means headphone makers design their products to meet that spec so they dont get complaints like my headphones dont work with my phone and device makers put this spec to make sure they dont get complaints like my headphones dont work with you crappy device.
Now there are out liers. Buy a super cheap product they may pinch pennies in the audio components to save money so they wont be able to. Older devices ten years or more (roughly) are more likely to not have good audio components.
Which is why the simple rule is if the device is reasonably modern and decent quality it will work with main stream headphones. (the DT990 etc is main stream)
It indeed depends on the power the device can provide.
My slightly old phone which is the Huawei Mate 20X has a built-in DAC which provides super sound but it can't drive both my DT7/8 and my Amiron Home that I actually own is the most efficient and it doesn't need to have volume bar maxed. My much older portable device, Samsung YP-U3 is easily able to drive my Amiron Home too. My Huawei P Smart Z can drive the DT7/8 250ohms with ease but its sound quality is crap, like really crap lol. But I expected it and it's not like I use my headphones for mobile use. I have the WF XM3 for convenience and Amiron Home for Netflix and both fits my needs perfectly.
And Beyerdynamic is indeed not stupid, in fact, they show on the box how many stars it as and also on their product pages. That's why they state the specs for users to buy the right version.
Amiron Home being harder to drive than 880, is the 880 250ohm too or other version like the Pro? I can speak from experience the Amiron Home is easier to drive on all my devices, wether be it desktop or portable. The 880 I own is the Black Edition 250ohm.
DAC/AMPs:
