Mini Itx Streaming Box
ltguy
Something for the bedroom to stream youtube, twitch, etc. Its overkill but I like to buy parts I can use again in other builds if my needs change.
case - Istarusa S-0112-DT with 120watt ac adapter (was $35 on sale so thats how i picked it)
motherboard - Gigabyte Z87N-WIFI
cpu - i3 4130
ram - 4gb gskill ddr3 1600mhz (stole from another build i wasnt using)
cpu cooler - Rosewill RCX-Z775-LP (fits like a glove ... 10 bucks.. highly recommend)
hard drive - toshiba q series pro 120gb ( last second best buy purchase because it didnt like the ssd i already had, very strange caused bsods and no drive found errors yet works fine in another machine)
Its very cramped and not much room for cable management. Added a little 40mm fan to cool the voltage regulator board since its the only thing that gets hot. Probably should have bought a thin mini itx board but wheres the fun in that. Sodims... no thank you.
Main Rig: http://linustechtips.com/main/topic/58641-the-i7-950s-gots-to-go-updated-104/ | CPU: Intel i7-4930K | GPU: 2x EVGA Geforce GTX Titan SC SLI| MB: EVGA X79 Dark | RAM: 16GB HyperX Beast 2400mhz | SSD: Samsung 840 Pro 256gb | HDD: 2x Western Digital Raptors 74gb | EX-H34B Hot Swap Rack | Case: Lian Li PC-D600 | Cooling: H100i | Power Supply: Corsair HX1050 |
Pfsense Build (Repurposed for plex) https://linustechtips.com/main/topic/715459-pfsense-build/
An i3 is in now way an overkill CPU for livestreaming
There are livestreamers with 2 Xeon E5 something or another costing nearly $2500 each ^_^ for JUST a streaming box
thats pretty cool
Specs
I'm just using it to watch streams, not broadcast them. I kinda made that confusing, my bad.
Ahhh :P that makes a little more sense now
You could have gotten away with a Celeron, to be honest, but I completely understand your reasoning for wanting headroom :) nice small build!
My Personal Rig - AMD 3970X | ASUS sTRX4-Pro | RTX 2080 Super | 64GB Corsair Vengeance Pro RGB DDR4 | CoolerMaster H500P Mesh
My Wife's Rig - AMD 3900X | MSI B450I Gaming | 5500 XT 4GB | 32GB Corsair Vengeance LPX DDR4-3200 | Silverstone SG13 White
Damn that looks tight.
Current rig: CPU: AMD FX-8120  Cooling: Corsair H100i  Mobo: ASRock 970 Extreme 3  RAM: 8GB 1333Mhz  GPU: MSI GTX 660Ti Power Edition  Case: Fractal Design Define R4  Storage: 2TB Seagate HDD + 128GB Crucial SSD  PSU: be quiet! 730W bronze
I recently had some time with a pentium g3220 and it seemed a little rough around the edges for streaming 1080p, so i went with the i3.
I agree, i'm thinking about getting the pico psu 160 (http://www.mini-box.com/picoPSU-160-XT) to replace the voltage regulator board it came with. The pico doesnt have the giant 24 pin cable and removing the circuit board in the front should give more some more room to tuck away cables.
the new i3's are great. i can't wait to have my build up and running. should be fun
Those cables seem really close to the fan in that cooler...
Does not having a second parenthesis around something bother anyone else as much as it does me? (Like if this statement was missing a second side)
I personally wouldn't have gone with a Z87 board with an i3 if it's soul purpose is to be a media PC. I would have gone with somewhere along the lines of an H87 or H85. Some H series boards do have built in Wi-Fi.
Good, small build though!
Yeah, probably due to the graphics more so than the CPU to be perfectly honest. I used my Celeron to stream with a dedicated graphics card and it's more than fine.
That makes sense though, because the major difference stepping up to an i3 is the integrated graphics, apart from that, you just get higher clock speeds and HT, neither of which should make a big impact on receiving and decoding streamed content anyway, HT maybe a little, but still, not worth the price premium in any way (an i3 is like double the price of a Celeron yeah?), so it's probably that iGPU.
Looks pretty cool, really compact.  Could you get some more photos? Im intrigued.
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
Exactly, and I knew i was using a case that didnt have an expansion slot for a dedicated graphics card so i got the i3. I was actually going to get the high end i3 with hd 4600 graphics, but after looking at the benchmark and specs its just a hair better and would have been $40 more.
Thanks!           I agree but i know me. Nothing i buy ever has  a "sole" purpse. This thing will likely one day be in a steam box build with a 4770k and a high end graphics card.
