Guys I had an desktop with e1-2500 apu for 7 years. It has 2gb Ddr3 running at 1600mhz. The motherboard is an kelia Daft3l
I just bought a gtx750 2gb and its lagging on high setting In and old left for dead 2. I don't know what to do. I can't buy a new pc. I'm stuck with it. Help me out
https://linustechtips.com/topic/1299928-im-stuck/
the CPU is probably just not good enough to play the game. check task manager to confirm this.
https://linustechtips.com/topic/1299928-im-stuck/#findComment-14436399
do you have any, and i litterally mean ANY other applications open in the background?
close the steam window exit discord and skype and spotify.
i'm afraid your hardware just doesn't have much horsepower* since it's old.
*it's not measured in horsepower but i think you get my point
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
https://linustechtips.com/topic/1299928-im-stuck/#findComment-14436424
Get new pc.. Or just motherboard, cpu.. Maybe get 2nd hand oldr system that support ddr3, like 4th gen Intel or like it. Should be fairly cheap
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1299928-im-stuck/#findComment-14436426
There's multiple limiting factors here, you have little ram that is eaten up by the OS and a slow cpu. Sadly you cannot upgrade your CPU since it's soldered directly to the motherboard, your best choice is getting a new motherboard+cpu+ram and maybe a PSU as well. Depending on where you live you should be able to pick up a cheap optiplex with a 2nd-3rd gen i5 and a bit of ram, then you can put your GTX 750 in there and it'll perform well.
https://linustechtips.com/topic/1299928-im-stuck/#findComment-14436435
You have barely any RAM and a slow CPU. I would very strongly suggest that you switch to a lightweight Linux distro instead of Windows (which I assume you're running now). It may or may not help with gaming performance (depends on the game and if the increase in performance from a lighter OS is greater than the decrease in performance because it's running on Linux) but it will help a lot with basically anything else.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1299928-im-stuck/#findComment-14436490
the amd APUs were slow to begin with (especially the lower tier ones like yours) you barely have enough ram your motherboard is a OEM one that has the CPU solderered in (so you cant change that either)
There isn't much to help you with, magic as far as I know isnt possible.
So you have either to run on potato graphics in hopes that your system can manage it
or next thing you can do is to buy a used office PC which still will be slow but much faster than yours e.g this one https://www.ebay.com/itm/Dell-Inspiron-530-Computer-with-Monitor-keyboard-and-mouse/362957497385?hash=item5481f3e429%3Ag%3A0EoAAOSwnFlef8gN&LH_BIN=1
(the link is just for reference I dont necesserily recommend this purchase make sure that if you buy it on ebay it has ebay buyer protection which appears on the screen if available and also make sure that in the description it says that it is working and has no faults if nothing is mentioned contact the seller, if you buy it from a forum listing or what not do not wire money use paypal or physically inspect the system before buying it)
Also make sure that the system has space (and PSU strong enough) to accommodate your graphics card.
P.S in case that wasnt clear, your GPU is fine enough to play left for dead at a normal resolution (e.g 1080p) the rest of your system especially the CPU is the problem that's why I recommended the purchase of a new one for a relative low price, in which then you can add your GPU later and play some games at normal or high graphics depending on the title (with the reference computer and your GPU do not expect to play cyberpunk at high graphics but counter strike, lol, left 4 dead would be playable at normal/high )
https://linustechtips.com/topic/1299928-im-stuck/#findComment-14436586
4 minutes ago, WikiForce said:
iirc, i ran that game at high settings 1080p with a hd 6850 which has only 1gb vram and afaik 750 is atleast 50% faster than that old beast (he mentioned 2gb vram so i wonder if it's a 750 ti which i currently own, so in that case it should be twice as fast) anyway, left 4 dead 2 is a game from 2009 and that gpu can run even gta 5 with lower settings, i never heard of a gtx 750 with 2gb vram so i am assuming he has a 750 ti which gives me stable 60-70fps in a much newer demanding game like GTA V at 1080p high (POST FX set to normal), i truly believe his ram being a bottleneck here, 2gb ram is barely enough for running windows processes itself let alone a triple a title, i really wonder if he can even browse properly with more than 2 tabs open without even running any app in background, he should atleast upgrade to 4gb if not 8gb (which i highly recommend) and an ssd for that snappy experience in windows 10
I am gonna updrade to 8gb ram
https://linustechtips.com/topic/1299928-im-stuck/#findComment-14437219
Are you me? because i'm also stuck at DDR3, 4790k with Z97 board
AMD 5000 Series Ryzen 7 5800X| MSI MAG X570 Tomahawk WiFi | G.SKILL Trident Z RGB 32GB (2 * 16GB) DDR4 3200MHz CL16-18-18-38 | Asus GeForce GTX 3080Ti STRIX | SAMSUNG 980 PRO 500GB PCIe NVMe Gen4 SSD M.2 + Samsung 970 EVO Plus 1TB PCIe NVMe M.2 (2280) Gen3 | Cooler Master V850 Gold V2 Modular | Corsair iCUE H115i RGB Pro XT | Cooler Master Box MB511 | ASUS TUF Gaming VG259Q Gaming Monitor 144Hz, 1ms, IPS, G-Sync | Logitech G 304 Lightspeed | Logitech G213 Gaming Keyboard |
PCPartPicker
https://linustechtips.com/topic/1299928-im-stuck/#findComment-14437226
10 minutes ago, WikiForce said:
makes no sense, same socket doesn't mean shit, i have a 7th gen ddr4 system now but still yours is miles ahead in terms of mobo, cpu and gpu
then it probably is, have fun it's decently powerful for older games and even some newer ones at lower settings as that extra 1gb vram compared to normal 750 will give you an edge and it's only 20% slower than my 750 ti, i think you can have decent gaming experience, atleast way better than before
great, sweetspot for low budget rn, can play many modern games if you don't run alot of things in background
Thank you very much
https://linustechtips.com/topic/1299928-im-stuck/#findComment-14437295
Is that a laptop CPU in a desktop
2 minutes ago, RAYTEX said:
A shop near me said he could change the cpu
"A shop near me" always makes me nearly cry. I've seen some shops near me charge £100 for a 250GB HDD replacement, they could have at least put an SSD in for that price. I would advise you to do this sort of stuff your self, there are lots of tutorials online and it is really easy to learn.
Please tag me @RTX 3090 so I can see your reply
https://linustechtips.com/topic/1299928-im-stuck/#findComment-14437315
1 minute ago, RTX 3090 said:
It is still a very slow CPU, what budget do you have. You could order a cheap Xeon combo from Aliexpress or pickup a used Dell or Lenovo from eBay for cheap
My current cpu is sodered
https://linustechtips.com/topic/1299928-im-stuck/#findComment-14437329
Why spend lot's of money having a new BGA CPU installed when the architecture is so old. I wouldn't justify doing it for a 5th gen laptop, and the A6 is like a 2nd gen intel. What is your budget ?
https://linustechtips.com/topic/1299928-im-stuck/#findComment-14437332
Just now, WikiForce said:
quadcore is still a decent upgrade i guess despite being a bit old and slow
No it isn't, the indivisual cores have very low performance to them. There is no point spending money to have a BGA chip soldered on, that's not exactly gonna be cheap
https://linustechtips.com/topic/1299928-im-stuck/#findComment-14437339
