Will it fry my PC?
saltwithchipsss
CPU: RYZEN 3 3200G (STOCK)
MOBO: BIOSTAR A320MH
RAM: CRUCIAL 2667MHZ 14-17-14-32-56 (1.35V)
SSD: 2.5" WD GREEN 240GB
HDD: SEAGATE BARRACUDA 500GB 7.2K RPM
PSU: P_20201209_152546_vHDR_Auto.thumb.jpg.64d8c711ec046ba32b1c384085e863cc.jpg
I just want to ask if I add a GTX 1650 gddr6 with a pcie 6 pin will it fry my PC?
This is the gpu i'm looking at buying
COLORFUL-Colorful GeForce GTX 1650 SUPER NB 4G-V
Idk the reliability of that psu but if it can't deliver its full wattage on the 12v rail, it can't be any good
So I recommend getting a new PSU
Get a Corsair cx550
-sigh- feeling like I'm being too negative lately
Yea that does not look reliable.. And even if your "Theoretical" power usage is below 400W, that PSU doesn't looks like to deliver all 400W of it..
And what is that "Rated Power Output 300W" over there?! O_O
Undoubtly YES ;\
it's actual power delivery capacity on the 12V rail (which is the one that matters) is 240W. While in theory 240W might be enough for a 3200g + 1650, that psu looks like a ticking bomb
Get a Corsair cx550
the only 2 psu available in my area are
*seasonic s12iii 550w
*corsair cv 650
don't know which to pick
*corsair cv 650
The cv650 would eb better. has DF but is not group regulated as S12III is so cv650 would be better
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
Since when is the S12III group regulated?...
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
Oh sorry, looked at the colum one down. It seemsl ike its DMA. Luke said it is between DC-DC and Group req?
Main PC:
Test Rig.
Just Sold
Ask me anything :)
so
cv:
100 more watts
Df and Dc-DC
S12III
LLC and DMA
100 watss less.
What is better?
Main PC:
Test Rig.
Just Sold
Ask me anything :)
7 minutes ago, SavageNeo said:
so
cv:
100 more watts
Df and Dc-DC
S12III
LLC and DMA
100 watss less.
What is better?
The former, of course...
