Wireless Laptop screen on desktop, how to make connection better
Go to solution Solved by Eigenvektor,
20 minutes ago, Akumatie said:
So what should I be using? I do find that going with something that requires a high bandwidth does just me a good 1 second or more input delay.
I did think having a good internet would just make that not matter
So does that mean if I go for example 720p 60hz would that just make the connection better and have less like to drop out?
There's probably not that much you can do in terms of latency.
Internet shouldn't come into play at all, unless the computer and screen are located in different homes. Otherwise it's all local network/Wi-Fi.
Reduced resolution will reduce the bandwidth requirement, but bandwidth and latency are not directly related. Lower resolution could potentially mean less time spent encoding/compressing which might help with latency if you're lucky. But otherwise latency is all about physical distance.
Best bet for an external screen is an actual screen connected through DP or HDMI. Anything wireless will have these limitations.
I am currently using my Lenovo Ideapad Pro 5 14APH8 laptop as a wireless display for my computer, both on the same network with a 900UP 900 down connection, computer is wired, laptop is wireless on the network.
I am using the laptop as a second screen but I am finding problems with stability and image quality, I am using the windows wireless display utility
The laptop screen is 2880x1800 120hz, but in the wireless mode if I choose the highest res I can only do 30hz, but if I go under 1080p I can do 60hz on the laptop display.
Is there anyway I can use full native res and 120hz?
And sometime after 4 hours the wireless utility just turns off needing me to connect the screen again which is really annoying when I am in the middle of a good gta speedrun.
Is there a way I could connect the laptop to the PC wired and just have a perfect no loss connection?
PC Specs https://uk.pcpartpicker.com/list/DV7RxH
Laptop Specs: https://psref.lenovo.com/Product/IdeaPad/IdeaPad_Pro_5_14APH8
Use an HDMI cable to connect the laptop to the desktop computer and use the same method you used when you connected it wirelessly. Windows should autodetect it.
I have just tried this, with connecting the both devices with a HDMI cable, still only allows me to use 60HZ at 1050p resolution, there is still a huge input delay when I use the second screen so I am not sure if the cable is doing anything?
You should be able to change both the resolution and the refresh rate thru the settings menu.
Depending on the GPU NVIDIA and Intel both have their own Graphics Control programs, I believe AMD does also, but I'm not 100% sure.
At any rate both monitors can have different resolutions and refresh rates and work together.
HDMI is unidirectional. You can't send video into a laptop and have it display.
Main System (Byarlant): Ryzen 7 5800X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 16GB G.Skill DDR4 3200MT/s CAS-14 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 960 PRO 512GB / 4× Crucial MX500 2TB (RAID-0) | Corsair RM750X | a 10G NIC (pending) | Inateck USB 3.0 Card | Hyte Y60 Case | Dell U3415W Monitor | Keychron K4 Brown (white backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi (all-around awesome machine)
Proxmox Server (Veda): Ryzen 7 3800XT | AsRock Rack X470D4U | Corsair H80i v2 | 64GB Micron DDR4 ECC 3200MT/s | 4× WD 10TB / 4× Seagate 14TB Exos / 8× WD 12TB (custom external SAS enclosure) / 2× Samsung PM963a 960GB SSD | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-16i HBA | Fractal Design Node 804 Case (side panels swapped to show off drives) | VMs: TrueNAS Scale; Ubuntu Server (PiHole/PiVPN/NGINX?); Windows 10 Pro; Ubuntu Server (Apache/MySQL)
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s CAS-22 | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | Mellanox ConnectX-2 10G NIC | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Camera: Sony ɑ7II w/ Meike Grip | Sony SEL24240 | Samyang 35mm ƒ/2.8 | Sony SEL50F18F | Sony SEL2870 (kit lens) | PNY Elite Perfomance 512GB SDXC card
Network:
                           ┌─────────────── Office/Rack ────────────────────────────────────────────────────────────────────────────┐
Google Fiber Webpass ────── UniFi Security Gateway ─── UniFi Switch 8-60W ─┬─ UniFi Switch Flex XG ═╦═ Veda (Proxmox Virtual Switch)
(500Mbps↑/500Mbps↓)                             UniFi CloudKey Gen2 (PoE) ─┴─ Veda (IPMI)           ╠═ Veda-NAS (HW Passthrough NIC)
╔═══════════════════════════════════════════════════════════════════════════════════════════════════╩═ Narrative (Asus USB 2.5G NIC)
║ ┌────── Closet ──────┐   ┌─────────────── Bedroom ──────────────────────────────────────────────────────┐
╚═ UniFi Switch Flex XG ═╤═ UniFi Switch Flex XG ═╦═ Byarlant
   (PoE)                 │                        ╠═ Narrative (Cable Matters USB-PD 2.5G Ethernet Dongle)
                         │                        ╚═ Jesta Cannon*
                         │ ┌─────────────── Media Center ──────────────────────────────────┐
Notes:                   └─ UniFi Switch 8 ─────────┬─ UniFi Access Point nanoHD (PoE)
═══ is Multi-Gigabit                                ├─ Sony Playstation 4
─── is Gigabit                                      ├─ Pioneer VSX-S520
* = cable passed to Bedroom from Media Center       ├─ Sony XR65A80K (Google TV)
** = cable passed from Media Center to Bedroom      └─ Work Laptop** (Startech USB-PD Dock)
Retired/Other:
Laptop (Rozen-Zulu): Sony VAIO VPCF13WFX | Core i7-740QM | 8GB Patriot DDR3 | GT 425M | Samsung 850EVO 250GB SSD | Blu-ray Drive | Intel 7260 Wifi (lived a good life, retired with honor)
Testbed/Old Desktop (Kshatriya): Xeon X5470 @ 4.0GHz | ZALMAN CNPS9500 | Gigabyte EP45-UD3L | 8GB Nanya DDR2 400MHz | XFX HD6870 DD | OCZ Vertex 3 Max-IOPS 120GB | Corsair CX430M | HooToo USB 3.0 PCIe Card | Osprey 230 Video Capture | NZXT H230 Case
TrueNAS Server (La Vie en Rose): Xeon E3-1241v3 | Supermicro X10SLL-F | Corsair H60 | 32GB Micron DDR3L ECC 1600MHz | 1x Kingston 16GB SSD / Crucial MX500 500GB
Unlikely. This would require a lot more bandwidth, which probably exceeds what is available wirelessly, even with compression.
2880x1800x30Hz -> 3.89 Gbps
1920x1080x60Hz -> 3.20 Gbps
Full resolution and refresh rate would have an uncompressed data rate of 16.25 Gbps.
