Arctic PWM Case Fan hub and Arctic P12 Max
Solved by RONOTHAN##,
5 hours ago, Libertaz said:Arctic PWM case fan hub like I stated in the title.
Whoops, I read that as just "PWM Case Fan hub and Arctic P12 Max," my bad.
That case fan hub can provide 1A per header and can provide 4.5A total, so given that the P12 Max at full blast draws 0.3A, if you filled up all 10 slots you'd only be using 3A, plenty of headroom for the adapter. You'd be more than fine with only 6 of those fans.
