PSU for 16pin (2 x 8 pin) CPU power
Solved by Grabhanem,
The dual 8-pin is somewhat common on modern high-end boards, where it actually matters sometimes. A single 8-pin can supply 384W, so you don't need to use the second unless you're doing extreme overclocking or something.
88pockets ·
Posted in General Discussion0 -
Awenor89 ·
Posted in Troubleshooting1 -
WiscoMetro ·
Posted in Audio0 -
Mihatzu ·
1
Yeatly ·
Posted in Graphics Cards2 -
8
Kevin.K.N. ·
Posted in Peripherals0 -
BANGINGxBT ·
Posted in CPUs, Motherboards, and Memory1 -
fergatronanator ·
Posted in Tech News1
play_circle_filled
Latest From Linus Tech Tips:
The Stealthiest Tech Upgrade - AMD $5000 Ultimate Tech Upgrade
