Does the included 5600X cooler (Wraith Stealth) allow max boost clocks?
kingmustard
I was considering buying a higher-end CPU cooler for the 5600X.
However, will the included cooler (the Wraith Stealth) allow max boost clocks, or will it limit the CPU in any ways?
I have good airflow in the case.
I will not be overclocking.
In single core workloads, unlikely.
In multi core workloads, probably!
These CPUs tend to boost higher when they are at a cooler temperature. The Wraith Spire isn't a bad cooler and will allow your CPU to perform within its rated specifications without overheating, but I've found my Ryzen 5 2600 can get as hot as 84 °C with it when doing a heavy multicore workload. This isn't hot enough to thermal throttle, but it isn't going to boost as high as an identical CPU at, say, 50 °C.
For gaming, this is fine. But if you're going to do any sort of heavy multi threaded workloads such as encoding or rendering, spending a little extra on an air cooler isn't a bad idea.
Edited by Kavawuvi
Should be no problem. Might not hold the boost for as long though, but yes the cooler is meant to work fine at stock.
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Noctua NH-D15 with one fan
FS in Denmark/EU:
Asus Dual GTX 1060 3GB. Used maximum 4 months total. Looks like new. Card never opened. Give me a price.
These CPUs tend to boost higher when they are at a cooler temperature. The Wraith Spire isn't a bad cooler and will allow your CPU to perform within its rated specifications, but I've found my Ryzen 5 2600 can get as hot as 84 °C with it when doing a heavy multicore workload.
Sinlge core boost is much cooler than multicore boost, so your statement dosen't make any sense.
FS in Denmark/EU:
Yup, I have no explanation for the "multi-core load is cooler than single core"
I edit my posts more often than not
My response was to this question:
but I'll edit my post to include that
It's been shown that Vermeer CPU's scale multi-core boosting into sub-ambient, which means all traditional coolers "limit" the chips in some way.
That being said, there's a case of diminishing returns with high performance coolers. Just run the stock wraith and decide for yourself.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Fedora 38 x86_64
Secondary: AMD Ryzen 5 5600G, 16 GB 2667 MHz DDR4, Fedora 38 x86_64
Server: AMD Athlon PRO 3125GE, 32 GB 2667 MHz DDR4 ECC, TrueNAS Core 13.0-U5.1
Home Laptop: Intel Core i5-L16G7, 8 GB 4267 MHz LPDDR4x, Windows 11 Home 22H2 x86_64
Work Laptop: Intel Core i7-10510U, NVIDIA Quadro P520, 8 GB 2667 MHz DDR4, Windows 10 Pro 22H2 x86_64
So you don't think a Noctua NH-L9a-AM4 chromax.black (£46) (I wanted a low profile cooler) will perform much better?
Why exactly that cooler if I may ask?
This one would be most likely much better :
https://www.amazon.co.uk/Gelid-Phantom-Black-Tower-Cooler/dp/B07CK6BXX5/ref=sr_1_2?dchild=1&keywords=gelid+phantom&qid=1605447012&s=computers&sr=1-2
My AIO cooler is on the wonk, but instead of getting another one, I will just go air.
I don't want a big, ugly tower fan, so I made this topic:
I decided on the NH-L9a-AM4 chromax.black as it was Noctua (so will be decent) and good-looking.
A guy tested this with a 2600 https://turbofuture.com/computers/Noctua-NH-L9a-AM4-CPU-Cooler-Review-and-Benchmarks
FS in Denmark/EU:
I looked for some reviews on the L9a and found something that may answer your question:
Quote
The Noctua NH-L9a beat out the Wraith Stealth cooler substantially, dragging the Wraith by roughly an 11 degree difference. The Wraith cooler was fairly weak here hitting a maximum of 88.9 degrees while the Noctua held up quite nicely hitting a maximum of 77.8 degrees.
I do think you can do better for the price, but yes, it will perform better.
EDIT: Seems DoctorNick ninja'd me on that
Edited by Kavawuvi
Just now, DoctorNick said:
Quote
Conclusion and Final Thoughts
So, there you have it. The Noctua NH-L9a is an impressive upgrade over the stock AMD Wraith Stealth cooler. Given the $40 price tag, this cooler is definitely a great alternative to the AMD Wraith Stealth for a quieter, more stable platform in a mini-itx/HTPC system. This is a cooler that I would absolutely recommend without reservation specifically for these “travel” mini-itx systems or home theater PC systems.
Appears it's quieter than the Wraith Stealth and performs a little better.
The performance difference between this and the Wraith Spire is marginal at best. It is not worth £46 for the performance alone.
https://www.phoronix.com/scan.php?page=article&item=noctua-nhl9-am4&num=2
1 minute ago, Tan3l6 said:
The cooling is somewhat mediocre to bad though.
https://aphnetworks.com/reviews/noctua-nh-l9a-am4-chromax-black/3
Yeah, but it looks good though!
FS in Denmark/EU:
I'd say its best use case is for a SFF PC case such as a Fractal Design Node 202 or a Silverstone ML08, since you can't fit a full-sized cooler in those.
It's not ideal for a full desktop cooler, but yeah, it does look nice. I know the Hyper 212 EVO is a meme cooler, but even that would be a bit better (and cheaper!).
But, even so, yes, the NH-L9A is better than stock.
I would get a bigger cooler for sure. But I would overclock until it..
FS in Denmark/EU:
AMD R7 5800X3D | Thermalright Phantom Spirit 120 EVO, 1x T30
Asus Crosshair VIII Dark Hero | 32GB G.Skill Trident Z @ 3733C14
Zotac 4070 Ti Trinity OC @ 3060/1495 | WD SN850, SN850X, SN770
Seasonic Vertex GX-1000 | Fractal Torrent Compact RGB, Many CFM's
