Grounding yourself when building
Go to solution Solved by sub68,
45 minutes ago, CloudPC said:
So should I scratch the paint off or not?
I'm very confused
no you dont need to scratch off the paint
Hey guys, this is just a follow up question to one I posted a few days ago.
So when grounding yourself to your psu. Should the plug socket that the PSU is connected to be switch on or off. I know the PSU should be off.
Thanks
System
CPU: Ryzen 5 3600
Case: Phanteks eclipse P400A
Motherboard: MSI B550 Gaming Carbon WiFi
GPU: MSI RTX 3060 TI Gaming X Trio
RAM: 16GB XPG D60G CL16 3200MHZ
PSU: Sharkoon SilentStorm Cool Zero 650W
Storage: Crucial P2 1TB
https://linustechtips.com/topic/1258926-grounding-yourself-when-building/
As in the actual wall socket? Doesn't matter. All you're doing is using your home's ground connection to dissipate static charge.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
I recently put in an X570 mobo in preparation for Ryzen 3 and one hint was to scratch the paint off the PSU grill and ground yourself on it (using a ESD band). AFAIK the PSU has to be connected to ground, meaning plugged in bit turned off (safety).
Is it true I need to scratch off the paint on the fan grill or is that not the case anymore?
I'm going buy an old tech quickie episode
System
CPU: Ryzen 5 3600
I have never grounded myself. Been working with hardware since the 90s, never killed anything through static discharge.
Intel i9-13900K - Gigabyte Aorus Z790 Elite DDR4 - Corsair Vengeance LPX 128GB DDR4 3200 C16 - Gigabyte Aorus Master RTX 4090 24GB - Corsair 4000D Airflow - 2x Samsung 980 Pro 1TB  - Corsair AX1600i 80 PLUS Titanium 1600W - Aorus FI27Q - Noctua NH-D15 running 3 fans (CPU) - 6 x NF-A12x25 (3 intake, 3 exhaust) - Aorus K1 - Aorus M5 - Aorus AMP500 - Aorus H5 - Corsair TC70 - Win 11 Pro
I did it "just in case", from what I have read is that any paint will keep you from grounding yourself.
I was working on my build for 5 hours, and not shocking something is possible but I don't want to risk anything.
That is because you are in a humid environment and you have been working in the golden age of ESD protection.
For example if humidity is below 30%, then things like paper and cardboard become static generators.  Depending on the humidity level, things that don't generate static charge can start to.
The golden age of static protection is from the 90s until a few years ago.  There is a reason that the ESD experts are either very old or pretty young.  We had a lot of years in there where we didn't care.  Parts before the 90s didn't have the protection so they were very sensitive and now because of the higher speeds and lower voltages the built in ESD protection circuits are getting smaller.  To keep the data eyes acceptable the circuits had to change.  As we go forward the danger of ESD is increasing.
Grounding yourself and your computer is always a good idea.  Sure you might not have a problem based on your particular situation but you might, and putting on a metal wrist strap that is grounded is cheap insurance.  (Don't use the cloth banded wrist straps, they are crap and have a high failure rate.)
Doesn't matter as much today as it used to back in the old days.
Today it's nothing to really worry about too much.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
I'm very confused
System
CPU: Ryzen 5 3600
@CloudPC No paint scratching - who does that?
I'm very confused
Everyone, Creator初音ミク Hatsune Miku Google commercial.
Cameras: Main: Canon 70D - Canon 7D MK2 - Secondary: Panasonic GX85 - Spare: Samsung ST68. - Action cams: GoPro Hero+, GoPro hero 6 black
Dead cameras: Nikion s4000, Canon XTi
Pc's
Towers:
Main Dell optiplex 5050 "Bandog"  - intel i7-7700 - nvidia t400 4GB - 20GB ram - 1TB Samsung 990 Pro heat sink - 256GB Samsung 850 - 5TB HDD
old windows 7 gaming desktop - Intel i5 2400 - lenovo CIH61M V:1.0 - 16GB ram - 1TB HDD
Laptops:
main laptop "Soppo": Lenovo P14s Gen 5 - Intel ultra 5 135H - Nvidia 500 ada - 32GB ram - Samsung 990 pro 1TB
Secondary/radio programming laptop "Klukai": Dell Latitude 5430 - Intel i7 1185G7- 16GB ram - Kioxia BG6 256GB
Tertiary/Networking/radio programming laptop "Persica": Dell latitude 5414 Rugged - intel i5 6300u - 12GB RAM - Samsung 870 EVO 500GB
Any questions? pm me.
#Muricaparrotgang
Linus back in the days he worked at NCIX
System
CPU: Ryzen 5 3600
Yeah, back then and earlier it mattered more.
Is @vsteel correct in saying that fabric Anti static bracelets are worse. Because that's what I brought.
System
CPU: Ryzen 5 3600
I don't know, I haven't used one in over 20 years now.
Yes, I am correct.  It might work but they have about a 20% failure rate out of the box and they don't last long.  It is part of what I do, ESD in the semiconductor field, I am friends with people who write the global standards.
Since you already have a fabric band, I assume it is one of the ones that have a snap.   If it is take the snap off and lick your finger and then put your finger on the metal part to discharge yourself.   Then you can put the snap on, and if the fabric is a little damp that will help as well.   If it doesn't have a snap, just get the fabric damp, not dripping wet but damp and make sure it has good contact with your skin.
You are just going to want to make the computer at a low charge level.  The parts you have, keep in a static bag until you are ready to use them.   Having highly charged parts touching a large ground plate is also bad.  ESD is not only the field that you might have on you which can damage parts, the quick discharge of parts can also cause damage.  That is why a lot of things go to ground in the mega-ohm range.  You need the charge to drain, not suddenly flow.   ESD can also cause weird issues, people think ESD will just make a part go poof.  While it can do that, it can also put a gremlin in the machine which can cause seemingly random fails which are infrequent enough they can be hard to track down.  It can also cause a shortened life of the parts because of internal damage, so it might take a few years off of your part.  Something dies after a year or two and you think you must have had a bum part, maybe you did or maybe you damaged it with ESD.
ESD does matter now.  Anyone that says it doesn't matter now is just using anecdotal evidence to make that statement.   It is your stuff though, you can do what you want.
Yeah, if you are working in clean room with very low humidity as they usually are and around electronics yeah it will make a difference.
But for more normal settings it doesn't matter as much as it used to back in the old days.
Nothing to really lose any sleep over.
Yeah, 15 to 25 years ago, oh yeah it mattered a lot.
We were just careful making sure we discharged any static before touching the parts.
Still have the same habit today making sure before touching the parts.
Clean rooms are kept at around 50%-70% humidity, along with probe, assembly and test.
I have said my peace, people can do with the information what they will.
