10850k stock cooler
By
Guest
in CPUs, Motherboards, and Memory
Solved by BlueChinchillaEatingDorito,
14 minutes ago, truckerlenny1990 said:i dont know if either cooler will run a 10850k stock. i just wanna get this system up and running.
If you're just installing Windows and programs, it's not going to be kicking out a ton of heat. Those two will be more than up to the task.
Featured Topics
bensinspade ·
Posted in Graphics Cards1 -
CloseTheDoor ·
Posted in New Builds and Planning3 -
pchelp ·
Posted in CPUs, Motherboards, and Memory8 -
pontikos ·
Posted in Troubleshooting2 -
7
wolfgangam ·
Posted in Windows3 -
12
