Dark rock slim with 3900x high idle
Solved by Moonzy,
20 minutes ago, Nerdom said:. Is that normal for a ryzen chip
perfectly normal and expected temps
running 3900x on dark rock pro 4, idle temp is ~53c, and it spikes (probably why your fan ramps)
under full load cinebench R20 it hits 77-79c
my ambient is 24-26c, depending on time of day
that said, i undervolted mine to 1.1v, so load temp is 66c stabilized, and no spikes during idle, so no fan ramp nonsense.
22 minutes ago, Nerdom said:Am I safe to change the curve so they only ramp up around 60-65c?
yeap, as long as load temps are fine
