is it possible to bend the motherboard pins while cleaning thermal paste ?
Solved by RejZoR,
If you look closely at the right side of the socket (which would be bottom side on your photo), the contacts are pointing from right side to the left. Left side is making the contact, right side is the base of the contact. What you'e seeing outside is the pin base.
Featured Topics
atxcyclist ·
Posted in Home Theater Equipment0 -
3
ElChales ·
Posted in New Builds and Planning4 -
Gundmi ·
Posted in Troubleshooting0 -
ElChales ·
naldo29 ·
Posted in Troubleshooting2
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
