Nearest case to Corsair Carbide SPEC-05 with no glass
rhanson
Go to solution Solved by Eschew,
Hey there. Sounds like you're looking for the CORSAIR Carbide Series 275Q? Almost identical to the Carbide SPEC-06, sans the TG side panel and PSU shroud.
Comparison Images:
1648294010_CC275Q-Exterior.thumb.png.86b638bfa153d994bd9e3f8d8adde8b0.png1477751469_CCS06-Exterior.thumb.png.b59c6116b9a48a27be4eee1fd244f614.png
2109331510_CC275Q-Interior.thumb.png.c964cf8461450ff5600c8f21b581146f.png1182874498_CCS06-Interior.thumb.png.9a3f7e8e2508e2fce9de07e3cc850c03.png
Left: Carbide 275Q. Right: Carbide SPEC-06.
Currently available on Newegg for $89.99, but at that price point, I'd really suggest looking at other cases. Ultimately, it's your choice, of course. 😉
Edit: Just noticed you're talking about the SPEC-05, not the SPEC-06. Well, snap. My bad. 😅
Hi all,
I am very new to PC building. I want to build a new PC following a similar schematic to an LTT video from a few months back (pre-pandemic) but I'm all about being discrete. In the video they use a Corsair Carbide SPEC-05, I'm looking for the nearest alternative case to this (price-wise as well) but with all metal panels.
Thanks
just get a 30$ case then.
Good luck, Have fun, Build PC, and have a last gen console for use once a year. I should answer most of the time between 9 to 3 PST
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Sapphire RX 6700XT  Nitro+, Corsair RM750X, 500 gb 850 evo, 2tb rocket and 5tb Toshiba x300, 2x 6TB WD Black W10 all in a 750D airflow.
GF PC: (nighthawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Strix GTX970, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb Adata XPG 6000 lite, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
PSU Tier List      Motherboard Tier List     SSD Tier List     How to get PC parts cheap    HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 60D, 24-105 F4, 50mm F1.4, Helios44-m, 2 Cos-11D lavs
Comparison Images:
正直に生きる、一度きりの人生だから
Keeb Weeb LinksCustom Mechanical Keyboards | #KeebWeebClub
'Chew Builds: Hoshī (PC) | Okashī (PC) | K-4398 (Keeb) | Eighty #391 (Keeb) | R2-968 (Keeb) | MGK64 (Keeb)
Comparison Images:
  Reveal hidden contents
Thank you. Yes a little bit expensive but gives me an idea what/where to look.
