4 or 8 pin CPU connecter
Solved by minibois,
19 minutes ago, Its N8 M8 said:
Found a nice cheap PSU on sale. I saw its on B+ tier on the tierlist. My only question is after looking at the amazon page I cannot find if it has a 4+4 Cpu connecter. Is it just 4 or is it 8 pin? Does anyone know?
For reference, this is the entire cable set that comes with this PSU:
You get two cables, that both have a single 4+4/8 pin EPS connector on it.
If you need the 8 pin? just plug them both in togehter. Only need 4 pin? unclip the two parts.
