I'm planning on moving soon and I was wondering what internet speed I should get. I would be moving into the city but it'll still be sorta on the city border if that makes sense.
Also what is the difference between megabite and megabyte several people have told me those 2 different options and I don't know the difference.
https://linustechtips.com/topic/1207973-need-help-on-which-is-which/
If you want help from us, post the different options available and we are welcome to help!
Depends on what you do on the internet and with how many people.
I would go for at least 30/3 Mb per person, but maybe more, depending on what you do.
MB = Megabyte
Mb = Megabit
1MB = 8Mb, as 1 byte contains 8 bits.
ISPs usually advertise in Mb, as that is a higher number
Just now, Nano Adam said:
Look at the Megabit (mb) when comparing internet speeds.
Okay so since I'm going to be living in the city which one should I get? I play online games and its just gonna be me.
Edited by Goku1814
Can you let us know the city ZipCode! And maybe a nearby address so we can look them up for you! (DO NOT give us your real address)
You don't wanna know what I am doing on the internet, but I can tell you, that I am doing that with a lot of people. 😏
If you'll have a lot of people on your network and can afford it go for gigabit but otherwise 200Mb/s is plenty in most cases.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
3 minutes ago, Goku1814 said:
100 megabyte for 20 a month 200 for 40 and 1 gigabyte for 75 a month
What the hell... meanwhile I’m over here paying $75 for 80Mbps... anyways go with whatever one you could afford, gigabit is nice but not necessary.
He says he is the only one, so 100mb/s is good enough! And, skip on the ISP provided equipment and go searching for your one! That will save you money! And try to get your installation fees waived also!
Okay thank you. I have maybe a roommate idk yet but that shouldn't be enough people to bottleneck the speed. Thank you guys
😳🤚 <("I have several concerns")
/s
Okay thanks
When it comes to online games Ping is more important than upload/download speed. I'd research the available ISP's in the area and see which is rated most reliable for the primary application. Beyond that upload/download speed is a matter of how fast you want to go and how long you're willing to wait when downloading/uploading. I'd pick a plan based on whatever price you're comfortable with. Paying for more speed just because someone recommends it may not translate into a worthwhile investment if you don't like the monthly price tag.
Depending on the ISP they might not let you change out their equipment and they might not charge for it. AT&T, at least for me, doesn't charge and I'm forced to use their router but I can put it in bridge/bypass mode. Spectrum gives you a modem for free as well.
Prior Build Log/PC:
Cox on the other hand charges you $10/month even if you return their equipment and use your own! That's going to change next year when the law that stops this BS takes effect but for now it can vary a lot by provider :(
Prior Build Log/PC:
True. Also, don't get caught in the "NEW" customer pricing, think about after 1 or 2 years how much they will charge you!
I have Xfinity, and we use our own modem without any fees from them!
