Adding a passive subwoofer to stereo amp
Laputacake
Hi,
I've tried having a look on google to see if anyone has tried this before but havent had any success so... I'm currently using a TPA3116d2 2.1 amp but im missing the sound of my old Class A amp but the only issue is the majority of older amps dont have any subwoofer output like the TPA. Would it be possible to use a low pass filter combined with a Y adapter to take the L and R signal from the amp combine them and then send that LPF signal to the passive subwoofer. Probably not the best explanation so enjoy some paint.
Thanks for the help
Steve
Yes it's possible though you wouldn't have direct volume controls on the speaker vs subwoofer ratio, what you're missing isn't your class A amp it's the lack of detail in those $10 class D single board amps.
Personally, I'd split the input signal, send it through the TPA for sub and class A for stereo, best of both worlds.
Sloth
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
Sloth
How would you be able to split the input signals to send only the low frequencies to the TPA? Or just send all the frequencies to both and have only the sub connected but that would still need the signals to be combined somehow.
Cheers
Steve
Cheers
You would use a crossover
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
2 hours ago, Laputacake said:
-snip-
Apologies, I assumed you had a crossover since you were trying to bridge the sub on the same amp outs as your stereo speakers,
Either buy a crossover or build one with passive components, it's really not hard.
Passive subwoofer D.I.Y. ?? - Techtalk Speaker Building, Audio ...
@rice guru
