FIRE! CPU power cable melted
15 hours ago, mariushm said:It could be tinned copper but I doubt it, most likely it's steel strands (as i said, steel is cheaper than copper but has higher resistance)
1007 refers to UL1007 standard wire and WV-1 is just a rating related to how well the cable insulation resists flames and self extinguishes (vertical flame test : http://fr.polymerinsights.com/testing/flammability/vw-1 ), 80c refers to maximum rated temperature and 300v is obviously maximum voltage.
The YC-HX may be a rating of the company that makes the cable that would differentiate it from cables made with other cables made with different number of strands and so on.
You can make burn tests or use magnets to detect type of wires
aluminum (copper clad aluminum wires are common in cheap ethernet cables) will shrink and twists when under flame (you can put stripper wire with aluminum under lighter flame and it will shrink and twist or bend right away
copper will remain the same.
Unless I'm mistaken, steel wire will be attracted by magnet while copper wire should not be... but I may be wrong.
Thanks, I'll try get hold of a magnet to test it. Do you know any good brands I could get some better quality extenders from?
