Air cooler for OC i9 9900k
HellTheCRoss
Hey guys, which one of these air coolers are better for an i9 9900k 4.7-5ghz OC: Deepcool Assassin III, Dark Rock Pro 4, Noctua NH-D15 or should I go for an AIO instead? I'll do more gaming and a little bit of video editing.
I've on this forum that dual tower coolers arent worth it's price. Dark Rock 4 isn't worse compared to the Pro 4, so I would go for the legend: Cooler Master Hyper 212X Dual Fan
Interim 15 T200 OKF("F" intel processors are specifically archituctured for gaming) maybe upgrad to 13'900 | Peeralight cpu fan | Stryx Z690-A Wife(which is branded by ASUS and it's ROG label) | Thermotake 16x 8x2GO SODINM 2400mjz cl22 (2 of them with the mood lighting) | 980 EVO 1TB m.2 ssd card + Kensington 2TB SATA nvme + WD BLACK PRO ULTRA MAX 4TB GAMING DESTROYER HHD | Echa etc 3060 duel fan dissipator 12 GBi and Azrock with the radian 550 XT Tiachi | NEXT H510 Vit Klar Svart | Seasonice 600watts voeding(rated for 100.000 hours, running since 2010, ballpark estimate 8 hours a day which should make it good for 34 years) | Nocturna case fans | 0LED Duel moniter
New build in progress: Ryen™ 8 7700x3D with a copper pipe fan | Z60e-A | Kingstron RENEGATE 16x2 Go hyenix | Phantek 2 the thar mesh in front | lead lex black label psu + AsiaHorse białe/białe | 1080 Pro 8TB 15800MB/S NvMe(for gaming this increase fps and charging time, cooled by a M.2 slot with coolblock and additional thermopad) and faster 4000GB HHD | MAI GeForce GTX 2070 Ti and RTX 6800 | Corshair psu
Hello,
They're all good but out of those the Deepcool is the best.
For reference :
D15. All day every day.
I wouldn't but the Deepcool just because of the companies either blatant false advertising, or not knowing what their products actually are.
Suggesting something like that without pointing out you're joking isn't funny.
5 minutes ago, Plouffe said:
Hello,
No, it's not. The D15 is better.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
NH-D15, a top performer and it has Noctua's very good mounting system, support, a 6 year warranty, etc. Still pretty much the best choice for high end air unless you only consider numbers on paper and don't care about anything else. They make a chromax one now too if you don't like the silver with brown fans.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
4.7GHz should be fine even with a single tower heatsink on almost any chip, as it's the stock all-core boost frequency.
I've personally been using a 9900K paired with a DRP4 and even with MCE turned on (basically a bad 5GHz OC), temps while gaming hovered around the low to mid 70s (in CPU intensive titles such as BF5) and 60s in less CPU heavy games. At 4.7GHz it will sit at about 60C even in CPU intensive titles, and mid 70s in stress tests.
I also run my fans quite slow though so if you don't mind turning them up a little you can get even better results in terms of temperatures.
I'd also suggest the NH-D15 - I would've also gotten one but they didn't have the chromax.black version out back when I was building my PC unfortunately. I believe it just edges out the DRP4 by a couple degrees, and should also be very quiet.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
AMD R7 5800X3D | Thermalright Frost Commander 140, TY-143
Asus Crosshair VIII Dark Hero | 32GB G.Skill Trident Z @ 3733C14
Zotac 4070 Ti Trinity OC @ 3045/1495 | WD SN850, SN850X, SN770
Seasonic Vertex GX-1000 | Fractal Torrent Compact RGB, Many CFM's
The d15 and the assassin3 will perform within a degree of each other but the assassin will be louder when pushed.
I believe the dark rock pro4 is really getting pushed at 5ghz 9900k. If less than 5ghz this would be fine.
I say go d15 or aio.
I use a NH-D15 with a i7 8086k at 5.1ghz(1.34v) and it idles around  33c.
I also have a i9 9900k at 5gz(1.27v) all cores using a NH-D15 that idles at 32c.
I have a Dark Rock Pro 4 sitting in a box because it won't fit over my ram. I hope I remember to buy low profile ram so I can use it in the future.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
Alright, the NH-D15 it is then. Btw, can I also ask what thermal paste I should go with? I know that nt-h2 from noctua aswell is a good choice. :)
1 hour ago, Plouffe said:
The Guru article you linked clearly shows the D15 as being better...
Same with the Tech5Gamers.
So. Not sure what you were trying to prove.
You didn't even read then as the Assassin III beats it by a little margin but still w/e, it's just facts that you didn't even show in the first place...
Guru:
Idle
D15 32
Assassin 35
Load
D15 74
Assassin 74
Tech4Gamers:
Stock
D15 20.85
Aassassin 20
OC
D15 39.4
Assassin 40.6
When you get up into higher end coolers, every degree matters when you're talking about differences in performance. The only one where the Assassin was better was the stock test by Tech4Gamers, and even then a fraction of a degree is margin of error.
So yes, while they're close on most tests, the D15 wins. It's better. It's cooler. You can't ignore the numbers and say that because the cooler you recommended is behind be a little bit that it doesn't matter.
Don't be so salty.
LGMRT performs as well as D15, and is quieter. Add a TY143  to leave the D15 at the back of the pack.
The cooler already comes with NT-H1 which is excellent. Most coolers come with decent paste.
13 hours ago, dizmo said:
Guru:
Idle
D15 32
Assassin 35
Idle temps are irrelevant for measuring raw performance. It's where there's little distinction between coolers from low to high end. As load increases, differences become the most clear. The extra performance also matters the most when cooling is more difficult so the best tests to look at are the heaviest ones.
The Tech4Gamers article shows a win on the 6850k oc for the NH-D15 and a loss for the NH-D15 on the 2700x oc -- Pretty even trade.
There were two 'guru' articles linked -- kitguru and guru3d.
Although guru3d shows a closer comparison, it's also probably a lighter load and less applicable for this comparison. The guru3d article shows 74c load with a 4790k (a 53c delta over 21c ambient) whereas the kitguru article shows a 62.5 vs. 63.1c for delta over ambient with the 9900k which is what the OP wants to cool. The larger delta is a good indicator of clearer results since cooler performance is harder to separate at lower temperatures.
It's a small difference indeed but Deepcool's claim for their Assassin III is 1c better than the NH-D15.
There are plenty of tests and reviews showing the coolers trading blows. Depending on which tests you focus on, which seems to be the better cooler can sway in either direction.
The Assassin III being placed higher is it seeming the better performer more often than not.
Along with the reviews already linked above, here's a non-exhaustive list of more results that can paint a fuller picture:
https://twitter.com/HardwareSci/status/1187427422016131072/photo/2
https://youtu.be/g0pv3g7A44I?t=466
https://youtu.be/wsEpHMQHBVM?t=371
https://m.hexus.net/tech/reviews/cooling/135152-deepcool-assassin-iii/?page=2
https://www.eteknix.com/deepcool-gamerstorm-assassin-iii-air-cooler-review/5/
https://play3r.net/reviews/cooling/gamerstorm-assassin-3-the-best-cpu-air-cooler/
https://www.ocinside.de/review/deepcool_assassin_iii/5/
https://tweakreviews.com/air-cooling/deepcool-gamerstorm-assassin-iii
https://www.techpowerup.com/review/deepcool-gamer-storm-assassin-iii-cpu-cooler/6.html
http://myc-media.de/deepcool-assassin-iii/
https://www.hardwaremax.net/reviews/kuehler/1606-test-deepcool-assassin-iii?showall=&start=5
https://www.tomshw.it/hardware/deepcool-assassin-iii-recensione/
https://www.computerbase.de/2019-10/deepcool-assassin-iii-test-kuehler/2/#abschnitt_messergebnisse
https://youtu.be/svnrP6Fr0jg?t=662
https://youtu.be/f8Se0qVKD1Y?t=167
The LGMRT sure is quiet but generally trades blows with the NH-D15S even with an additional fan.
Most high performance large air coolers show at least a few instances of beating other dual towers by a significant margin whereas the LGMRT is shown barely trading blows at best. Its best showing is likely from tweaktown where it's ahead of the NH-D15 but the load is light enough that the Brontes and MasterAir Pro3 can both keep temps in check at 83c. https://www.tweaktown.com/reviews/7986/thermalright-le-grand-macho-rt-cpu-cooler-review/index6.html
https://youtu.be/0fq-oi7p6r4?t=655
https://www.nikktech.com/main/articles/pc-hardware/cpu-cooling/cpu-air-coolers/7107-thermalright-le-grand-macho-rt-cpu-cooler-review?start=5
https://www.pcgameshardware.de/Luftkuehlung-Hardware-217993/Specials/Thermalright-Le-Grand-Macho-Test-Review-1216603/
https://www.hardwaremax.net/reviews/kuehler/1301-test-le-grand-macho-rt?showall=&start=4
https://www.hardwareluxx.de/index.php/artikel/hardware/kuehlung/38997-thermalright-le-grand-macho-mit-ty-147-b-im-nachtest.html?start=4
https://www.pakgamers.com/reviews/thermalright-le-grand-macho-cpu-air-cooler-review/
https://www.techpowerup.com/review/thermalright-le-grand-macho/6.html
