Advice on components for X-Plane 11 and MFS2020
Hi,
I play flight simulators for a long long time and now that Microsoft Flight Simulator 2020 is around the corner I want to upgrade my "old" PC to prepare it for the new sim and also get a boost in Xplane 11 performance.
At the moment I'm getting around 20-25fps on a 1440p monitor but at the cost of only getting medium graphics settings and getting below 15fps or less in some scenarios.
So what I have now is:
Motherboard: Asus p8z68-v gen3
CPU: i5 2500k
RAM: 2x8Gb DDR3 1600 (from what I remember...)
GPU: GTX 1660 6Gb
What I'm thinking to buy:
Motherboard: Asus Prime B450-Plus
CPU: AMD Ryzen 7 3700X
RAM: Corsair 32Gb Vengance LPX (2x16Gb) DDR4 2666MHz PC4-21300 CL16
Cooler: Noctua NH-D15
I will keep my case, Power supply and Graphics card for now.
My monitor is a Dell 1440p 27'' 1ms 144Hz with FreeSync.
I also want to buy new storage. I think an M.2 SSD would be the way to go but I don't know nothing about that.
So, what do you think? Any changes that I should do?
The budget is around 700€ (~772$) but I'm open for suggestions.
Thank you.
I would suggest going for a less expensive cooler, something like a Dark Rock 4 or NH-U12S will do for the 3700X, as long as you don't plan on doing heavy manual overvolting.
When it comes to B450 boards, MSI's are about the best you can get, my suggestions would be the Tomahawk, Gaming, Mortar and A Pro, and particularly the "Max" version of either board, as those come ready for Ryzen 3000 out of the box.
Ryzen loves fast memory, so I'd grab a 3200MHz kit, or 3600 if it's not much more expensive.
Also, if all you do is gaming on your PC, you could go for a Ryzen 3600 and not really lose much gaming performance, and save a bit of money.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
Thanks Mateyyy,
From your advices I got this:
My First Choice
Motherboard Asus Prime B450-Plus      97,90 €
CPU AMD Ryzen 7 3700X    348,70 €
RAM Corsair 32Gb Vengance LPX (2x16Gb) DDR4 2666MHz PC4-21300 CL16    145,90 €
Cooler Noctua NH-D15      89,90 €
  TOTAL    682,40 €
Option 1
Motherboard MSI B450 Tomahawk Max    115,90 €
CPU Ryzen 7 3700X    348,70 €
RAM RAM Team Group 32GB (2 x 16GB) DDR4 3200MHz Dark Z Red CL16    120,82 €
Cooler Noctua NH-U12S      57,90 €
  TOTAL    643,32 €
Option 2
CPU Ryzen 5 3600X    231,23 €
  TOTAL    525,85 €
Changing the RAM to a "RAM G.Skill 32GB Sniper X (2x16GB) DDR4-3600MHz CL19 Urban Camo" will increase 32€.
From what I see, the Ryzen 5 3600X and Ryzen 7 3700X are very similar with a big difference in price so maybe your're right about going for the 5.
3 minutes ago, zephirus said:
Noctua NH-U12S
A bit overpriced. Similar performance can be had from arctic freezer 34 esports duo or coolermaster hyper 212 rgb black edition or even a gelid phantom if you can find one. All these will be cheaper with similar cooling performance (maybe a bit louder).
Thanks. I will definitely go for the Noctua just because after trying others I really like this brand. It's indeed very quiet. But thanks for the suggestions! Really appreciate all the help I can get.
Noctua NH-D14 should be 5 euros or so more expensive than the u12s with much better performance, then
@Mateyyy I think I will go for the Ryzen 5 3600X as you suggested. I will get more or less the same performance right?
About the motherboard, it's a good choice for the future? I mean, if I want to update later I will be good with this one?
Thanks
Thanks
Always quote so we can be notified whenever you reply (for example I wasn't aware that you responded yesterday haha).
The Tomahawk Max should be good for up to a 3900X, so yes, it is a good option.
If you plan on running an aftermarket cooler anyway, you could just go for the 3600, unless you can get the X for the same price, as they will be almost identical in performance when running with good cooling.
Thanks!
So, 3600X if it's same price as 3600 with a good cooler. 3700X is definitely not worth the difference.
Thanks to all that helped out!
I asked a friend about what he thinks about this upgrade and of course now I'm more confused.
Currently, my motherboard is the Asus p8z68-v gen3 and it only supports DDR3 RAM but in fact I can put a more recent CPU, either i5 ou i7.
This way I could keep my current board and save some money.
So, as an alternative to the Ryzen 5 3600, is there a better option going to intel? Should the RAM support being only DDR3 be a bootleneck?
I mean, if the games you play don't require 6+ cores to run without issues, an i7-2600 or 3770 could improve your experience by a decent bit because of the extra 4 threads. Single-core performance won't improve by much, if at all, though.
I would only suggest you go this route if you find a particularly great deal on either of the CPUs I've mentioned, and if you think 4C/8T will be enough for you until you go for a full platform upgrade.
For X-Plane I will not get a better performance because it mainly uses 1 core. Maybe for the next Microsoft simulator it would be noticable but I start to notice that, unless I go to oither CPU values, I will not see great changes in performance.
After some thinking and advices from friends, I got to the components attached.
Any thing that I can/should change?
EDIT: I can get everything for 522,51€
Thanks!
Edited by zephirus
Change in price
Thanks!
Looks good!
