Motherboard RGB not working
Go to solution Solved by ddennis002,
Just now, wedgevic said:
Nope, stil not working :(
Not sure what else to tell ya, Im not a fan of MSI myself and don't personally own that board thought about buying it at one time but I won't go there. Maybe contact MSI or hopefully someone with that board will come along and chime in. ?
For whattever reason, the RGB on my MSI x370 Gaming Pro Carbon does not work, I have tried mystic light 2.0, 3.0, MSI gaming app, instaling linux  and even reinstalling windows, but nothing works!
Thanks in advance,
Daniel
Current Specs (Am building a mini ITX PC, will take a while)
CPU                                   RAM                                             Motherboard
Ryzen 7 5700G              16GB unbranded 2666Mhz           Asus ROG Strix  x570-i
GPU                                  Case                                              Boot Drive
EVGA GTX 1060           SSUPD Meshlicious                  Corsair MP500  500GB
Headset                           FBT                                                Extras
Quest 2                       Waist+Chest on OwOtrack                VIVE DAS
When it is finished
CPU                                   RAM                                             Motherboard
Ryzen 7 5700G              32GB Corsair LPX 4200Mhz     Asus ROG Strix  x570-i
GPU                                  Case                                              Boot Drive
ASUS RTX 3070          SSUPD Meshlicious                  Corsair MP500  500GB
Headset                           FBT                                                Extras
Quest 2                       Haritora-X/Slime VR                VIVE DAS + LucidVR Gloves + BHaptics vest
https://linustechtips.com/topic/1114373-motherboard-rgb-not-working/
Thanks in advance,
Daniel
Some motherboards have options to turn RGB on and off in BIOS have you checked there?
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
yes, I have even done a BIOS flashback
CPU                                   RAM                                             Motherboard
GPU                                  Case                                              Boot Drive
Headset                           FBT                                                Extras
When it is finished
CPU                                   RAM                                             Motherboard
GPU                                  Case                                              Boot Drive
Headset                           FBT                                                Extras
Looks like MSI gaming app is what you need for light support.
http://download.msi.com/uti_exe/gaming_app_6.zip
Internet Connection
Passmark Score
3dmark Score
Network
CPU                                   RAM                                             Motherboard
GPU                                  Case                                              Boot Drive
Headset                           FBT                                                Extras
When it is finished
CPU                                   RAM                                             Motherboard
GPU                                  Case                                              Boot Drive
Headset                           FBT                                                Extras
CPU                                   RAM                                             Motherboard
GPU                                  Case                                              Boot Drive
Headset                           FBT                                                Extras
When it is finished
CPU                                   RAM                                             Motherboard
GPU                                  Case                                              Boot Drive
Headset                           FBT                                                Extras
Internet Connection
Passmark Score
3dmark Score
Network
